07-16-2015, 06:09 | #1 (permalink) |
Product Supporter Join Date: Mar 2008 Location: Thailand Age: 46
Member: 716581 Status: Offline Thanks Meter: 767 | SC7715 imei change Done. Pls add unlock network for this(sc7715) Thank you for advance. |
The Following User Says Thank You to nongmobile For This Useful Post: |
09-16-2015, 09:02 | #4 (permalink) | |
Freak Poster Join Date: Jul 2006 Age: 38
Member: 307225 Status: Offline Thanks Meter: 59 | Here Is Log From Phone Quote:
09-16-2015, 09:07 | #6 (permalink) |
Member: 307225 Status: Offline Thanks Meter: 59 | Its Give Error While Reading NV Operation : Read NV [ v1.05 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 680 ] Port Opened Sync... Initial Boot Failed! Reconnect Power/Cable! |
09-16-2015, 09:11 | #7 (permalink) | |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Quote:
Follow software log hints and connect phone. Re-insert battery before connect. | |
09-16-2015, 09:43 | #12 (permalink) |
Member: 307225 Status: Offline Thanks Meter: 59 | Chinese Miracle II [SPD module] v 1.05 Operation : Check/Read Info [ v1.05 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 680 ] Port Opened Sync... Initial Boot Failed! Reconnect Power/Cable! Operation : Check/Read Info [ v1.05 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 680 ] Port Opened Sync... Initial Boot Failed! Reconnect Power/Cable! Operation : Check/Read Info [ v1.05 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 680 ] Port Opened Sync... Initial Boot Failed! Reconnect Power/Cable! |
01-04-2016, 13:18 | #13 (permalink) | |
Freak Poster Join Date: Jun 2008
Member: 784847 Status: Offline Thanks Meter: 45 | Quote:
plz help keys are also ok | |
