Old 10-10-2009, 17:49   #1 (permalink)
Member: 411207
Thanks Meter: 164
procedure to unlok KP 170 with infinity success 100/100
procedure to unlok lg KP170 step by step
1- cable needed:
* cable KE500
if you haven't cable use pin finder cable L18b RX=16 and TX=17
like picture
2- run shell software select KP215 model
3- run format ffs
like picture:
phone is unloked successufly safe
this is my expérience with kp170
The Following 2 Users Say Thank You to blaw For This Useful Post:
Old 10-10-2009, 19:48   #2 (permalink)
deepakgarg's Avatar
Member: 220603
Thanks Meter: 1,164
please read full flash from kp170 and send to support
Old 10-22-2009, 08:17   #3 (permalink)
jainmunda's Avatar
Member: 84128
Thanks Meter: 110
after that imei goes to all zero and always saying sim card registration failed
Old 11-08-2009, 14:41   #4 (permalink)
Member: 815644
Thanks Meter: 56
kp170 unlock success
infinity teem,
ihad unlock kp170 with infinity.
i slect kp215 model and format it.
now my set is unlock but phone imei gone to 0000000000000.
loner is given below
COM3 [VCP0] selected
module v1.39
Device: LG-KP215
Checking data, wait...
Action: imei repair
Boot ...
Connecting, wait...
Release Power button now !
flash: 01227E223C2200:FEEA0000000000
flash: Amd AMD/Fujitsu std [D 0004x010000 007Ex040000 0004x010000] 32Mb
Boot Done
Set baud ...
115200
Set baud Done
Check flash ...
current eeprom imei: 354789654125426
file saved: C:\Program Files\InfinityBox\LGA\eeprom_354789654125426_LG-KP215_20091109-062850.B1E.bin
Check flash Done
Check space ...
Check space Done
Check parameters ...
Check parameters Done
Erase ...
Erase Done
Write ...
Write Done
Finished, time used: 64 sec
Remove/Install battery now !
The Following User Says Thank You to bilal_mobile For This Useful Post:
Old 12-03-2009, 23:26   #5 (permalink)
Blocked
Member: 162707
Thanks Meter: 66
Hi after unlock i can't get any signal. Can you please help me? The imei is all zeros, can't infinity repair the imei? Am awaiting your speedy response.
Venom
Old 12-03-2009, 23:56   #6 (permalink)
Blocked
Member: 162707
Thanks Meter: 66
I got it!!!!! I even have restore the original imei with infinity. Thanks infinity your tool IS THE BEST!!!!!!!!!!!!!!!
Venom
Fr Jamaica
how to unlok kp 100 lg plz halp parmodparmod Infinity-Box 6 12-20-2009 07:46
pls help me to unlocking KP-500 With furious gold. morya FuriousGold 1 04-29-2009 08:43
whats the procedure to unlok e1?? peter002 Smart-Clip 26 03-17-2009 17:59
can i unlock lg kp-202 with infinity? svchost Infinity-Box 1 11-13-2008 00:03
need procedure to flash t-191 with ufs3 cliffrock4u005 Motorola ODM 2 10-21-2005 15:11
Page generated in 0.17745 seconds with 9 queries
