08-21-2011, 18:37 | #1 (permalink) |
No Life Poster Join Date: Oct 2007 Location: AROUND THE WORLD
Member: 617412 Status: Offline Thanks Meter: 177 | huawei g7010 problem then i did flash to phones after flash phone turn on with sim card, but on display software eror 23. what is this i did try 2 aur 3 files but same problem without sim phone worked well but with sim phone turned on but on display written software error 23 please help me, |
08-21-2011, 18:54 | #2 (permalink) |
Member: 617412 Status: Offline Thanks Meter: 177 | COM5 [VCP0] selected module v3.98 Device: Huawei-G7010 Checking data, wait... Action: write flash write: Firmware Huawei-G7010_HUAWEI53_09B_PCB01_GPRS_MT6253_S00.ESPC113B1 46SSC.BIN_FLNTY6701111184KC__fullflash_20110809-182807.B0M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs nor area detection... "format ffs" active interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6253:8A02:8A00 status: FF bbchip bl ver: FE NOR flash id[00C0]: 0098:009E00000000 [TOSHIBA] TC58FYM7T8C chip size: 16Mb otp status/size: S_DA_NOR_OTP_EXIST/00020000 NAND flash chip: not installed internal RAM size: 00020000 external RAM: absent done Set baudrate (115200)... done ram test... testing 32bit... 32bit ram test passed testing 16bit... 16bit ram test passed ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 00000000/00000000 detect sec ro... detect custom parameters... detect project-id... project-id: ESPC113B199SSC detect NOR info... number of areas/bytes to read: 1:00050000 reading (HW_STORAGE_NOR)... TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done rom info ver: 07 sw version: HUAWEI53_09B_PCB01_GPRS_MT6253_S00.ESPC113B199SSC. BIN_FLNTY6701111184KC project-id: ESPC113B199SSC, 00000000 code offset: 00000000 ffs offset/size [02]: 00DC0000/00240000 rom info structure: [standard] type (07) TCL-ID is absent ===> done startup code area #1 check... done number of cores: 1 loading files... number of areas: 1 done write... write core... Format... autodetection mode... Format done Disconnect... done Finished, time used: 28 min 6 sec Remove/Install battery now ! just now i did agian this flash but same problem when put another sim card ON DISPLAY SOFTWARE ERROR 23 WHAT A TEAM NOBODY GIVING RESPONSE ALL SLEEPING HUMMMMMM |
6150 Lock Problem | Zeljko | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 10-16-2013 08:16 |
GId1 problem | old_man | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 10-18-2006 15:21 |
6110 5.47 sw unlock problem | gsms | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 11-21-1999 19:43 |
HELP: Problem with 5110 | Xabi | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-16-1999 00:44 |
