06-11-2011, 07:31 | #1 (permalink) |
Freak Poster Join Date: Jan 2005 Location: RO Age: 47
Member: 104946 Status: Offline Thanks Meter: 33 | ALCATEL OT-806- can"t reflash ,can"t format module v3.31 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: read/check information ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6235:8A04:8A01]... CPU: MT6235 high speed boot On chip: 0000:0000:8003 status: 02 boot packet size: 0400 error: bootcode start error: A4 not authorized: 000000A4 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... error: no any expected answer : wrong answer after chip cfi request number of flash chip/regions detected: 00/01 flash chip is unknown or damaged. Fault reasons: 1. unknown hardware: contact to support: [email protected] 2. hardware is damaged: check hardware, water inside etc. Initialize Fail Finished, time used: 31 sec Remove/Install battery now ! I removed the metallic shield over flash an d mcu FLASH MODEL : ST : NAND A 9W3N6 CZBB5 HO 6A012 80 CHN 99 028 MCU :MEDIATEK MT6235 BSA i re-hot the mcu +flash but the result log is the same at before. Pin-out connected as alcatel C701. The phone is very clean no other broken hardware is visible and no water inside. Action: read/check information Model: Autodetect 6205-6239 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... Phone detected, wait... Hardware version: MT6235, E04 Hardware version: JRD35_09B_HW Software version: MAUI.09B.W09.52.SP1. Software date: 2000.00.00 Barcode: MT01234567890123xxxx imei-1: 35263304007xxxx Finished, time used: 18 sec Remove/Install battery now ! COM36 [VCP2] selected module v3.31 Device: Autodetect 6228-6268 NAND Checking data, wait... Action: read firmware NAND interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! bootcode current/expected: 0.0/3.2 CPU: 6235:8A04:8A01 status: 02 bbchip bl ver: FE NOR flash id[0000]: 0000:000000000000 [AMD] AM29DL323D chip size: 0Mb otp status/size: S_DONE/00000000 NAND flash id[0000]: 0000:000000000000 [SAMSUNG] K9F5608Q0C chip size: 0Mb page/spare size: 0000/0000 pages per block: 0000 bits i/o: 00 address cycles: 00 internal RAM size: 00000000 external RAM [HW_RAM_UNKNOWN, CS0] size: 00000000 sec error code: AA error: can not boot device: 1772:S_SECURITY_SLA_INVALID_AUTH_FILE error: last error: 1772:S_SECURITY_SLA_INVALID_AUTH_FILE Disconnect... done Finished, time used: 8 sec Remove/Install battery now ! with another tool : Connecting ... Flash ID.: 2000F100 , Intel 64 Mb. Phone IMEI : 352633-04-007481-9 Firmware Ver. : 26d Connecting ... Flash ID.: 2000F100 , Intel 64 Mb. Phone IMEI : 352633-04-007481-9 Firmware Ver. : 26d Phone Type : 806X-2ACSRO1 Operator/Country : Unknow / ROMANIA Language : EN ROM ITAL DEUT MAGGYAR Phone Connected Ok.. Phone Type : 806X-2ACSRO1 Operator/Country : Unknow / ROMANIA Language : EN ROM ITAL DEUT MAGGYAR Phone Connected Ok.. When will suport infinity this phone? |
I need flash to Alcatel One Touch Viev db: Be 3, 2 mb,16A | sosin | Alcatel & TCL Old Models | 0 | 02-13-2002 03:47 |
Dejan Flasher PCB in .dfx Format | ahmed | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 07-10-2001 16:06 |
NOKIA, ALCATEL EEprom site | Orbital - GSM | GSM Mobile Links | 0 | 04-09-2001 10:31 |
complete N3210 service manual in pdf format | frfr | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 04-08-2001 11:02 |
