10-10-2009, 10:16 | #1 (permalink) |
No Life Poster Join Date: Apr 2007 Location: BIRMINGHAM UNITED KINGDOM Age: 34
Member: 488632 Status: Offline Thanks Meter: 391 | Alcatel ot-s319 no service saloution 100% tested AND FLASHED WITH S319A FORMATE WHOLE FLASH CHIP HERE IS LOG COM1 [VCP0] selected module v2.91 Device: Alcatel-S319X, S319A Checking data, wait... advanced flash detection enabled Action: erase flash chip Do you want to make ffs/eeprom backup before format ? ffs/eeprom backup enabled, it may takes several minutes ! Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:2F89:A00C status: 01 boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 98000300000001:2AEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud ... 115200 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... detect device rom info... detection phase #1... detect device rom info finished rom info structure: 2nd [standard] generation rom info detection finished rom info protocol ver: 05 ver. sw 1: JRD23_07A_PCB01_GPRS_MT6223_S00.MAUI_07A_W07_36_SP 1_V20.BIN ver. sw 2: MAUI.07A.W07.36.SP1.V20, 00000000 ffs offset/size: 00C00000/00400000 ffs address assigned: 00C00000 TCL identification... version: 16T provider: S319X-2GALGB1 customization: XH16AE31 TCL identification done detect device sec info... detect device sec info finished sim-lock status: disabled product id: JRD_COMMUNICATION_U82X_PRODUCTS area1 is invalid area2 is valid area3 is valid area4 is valid Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... reading: Alcatel-S319X,S319A_JRD23_07A_PCB01_GPRS_MT6223_S00.MAUI_0 7A_W07_36_SP1_V20__ffs... file saved: C:\Program Files\InfinityBox\MModule\Alcatel-S319X,S319A_JRD23_07A_PCB01_GPRS_MT6223_S00.MAUI_0 7A_W07_36_SP1_V20__ffs_20091010-012146.B0E.bin flash: 98000300000001:2AEA0000000000 Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... Write Done Finalization ... chip formatting... flash: 98000300000001:2AEA0000000000 Erase: chip 1 of 1 Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-S319X,S319A_JRD23_07A_PCB01_GPRS_MT6223_S00.MAUI_0 7A_W07_36_SP1_V20__system_log__FFFFFFFF_20091010-012337.B0X.bin Finished, time used: 571 sec Remove/Install battery now ! AFTER FORMATING FLASH UR PHONE WITH IF PHONE BACK LABLE OT-319X S319X-2GALGB1_XH16AE31_JRD23_07A_PCB01_GPRS_MT6223_S00[1].MAUI_07A_W07_36_SP1_V20_2009-02-04_En_Fr_De_Nl_Tr_simfree.B0M AFTER FLASHING POWER ON IF PHONE POWER ON OK THEN DNT FORMATE IN COMPLETE MODE AND NO NEED TO REPAIR SECURITY AREA IF PHONE DNT POWER ON THEN FORMATE IN COMPLETE MODE + REPAIR SECURITY AREA HERE IS FLASH LOG COM1 [VCP0] selected module v2.91 Device: Alcatel-S319X, S319A Checking data, wait... advanced flash detection enabled Action: write NOR flash "smart write" active write: Firmware S319X-2GALGB1_XH16AE31_JRD23_07A_PCB01_GPRS_MT6223_S00[1].MAUI_07A_W07_36_SP1_V20 _2009-02-04_En_Fr_De_Nl_Tr_simfree.B0M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs enhanced security fix enabled Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:2F89:A00C status: 01 boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 98000300000001:FFFFFF00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud ... 115200 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... detect device rom info... detection phase #1... . detection phase #2... .................................................. .............. warning: rom info information not found, possible reasons: .old firmware type w/o rom info data .damaged firmware .damaged hardware if phone works fine just ignore this warning detect device rom info finished ffs address can not be detected, value from database assigned: 00C00000/00400000 TCL identification... version: ÿÿÿÿ customization: ÿÿÿÿÿÿÿÿ TCL identification done detect device sec info... . detect device sec info finished Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... detect device rom info... detection phase #1... . detection phase #2... .................................................. .............. warning: rom info information not found, possible reasons: .old firmware type w/o rom info data .damaged firmware .damaged hardware if phone works fine just ignore this warning detect device rom info finished ffs address can not be detected, value from database assigned: 00C00000/00400000 detect device sec info... . detect device sec info finished startup code area #1 check... startup code area #1 fixed Area: Firmware flash: 98000300000001:FFFFFF00000000 Write: Firmware detect device sec info... detect device sec info finished sim-lock status: enabled product id: JRD_COMMUNICATION_U82X_PRODUCTS area1 is invalid area2 is valid area3 is valid area4 is valid security area (sec info, part #2) calculation... customization: CH16AE31 done flash: 98000300000001:2AEA0000000000 flash: 98000300000001:2AEA0000000000 Write: security area (sec info, part #2) security area (sec info, part #2) calculation done security area (sec info, part #1) calculation... use default security area (sec info, part #1) pattern ..................region counter set: 01 security area (sec info, part #1) detecting size... security area (sec info, part #1) detecting parameters... security area (sec info, part #1) encoding... done flash: 98000300000001:2AEA0000000000 flash: 98000300000001:2AEA0000000000 Write: security area (sec info, part #1) security area (sec info, part #1) calculation done Write Done Finalization ... Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-S319X,S319A__system_log_20091010-015312.B0X.bin Finished, time used: 1440 sec Remove/Install battery now ! DNT FORGET TO PRESS THANKS BUTTON BR YASERMALIK |
The Following 2 Users Say Thank You to yasermalik For This Useful Post: |
10-10-2009, 11:04 | #4 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Here is an instruction how to get cable/pinout information: 1. be sure that you have downloaded and installed latest Infinity-Box Pinouts update 2. run Infinity-Box Shell 3. select required model 4. see detailed information about cable/pinout (Rx/Tx/Gnd pins and other information) Here is an example of information given by Infinity-Box Shell: Here is information how to build your own cable: http:///vbb/showthread.php?t=342807 |
1202,1203,1661,5030, NEW audio saloution 100% tested | gsm junction | Nokia Hardware & Hardware Repair | 19 | 12-15-2010 09:42 |
alcatel ot-s319 correct pinout and tested | MGT SOFTWARE | Infinity-Box | 4 | 03-28-2010 17:14 |
Alcatel s319...no service | Frenzy_2020 | Infinity-Box | 8 | 10-08-2009 14:22 |
Alcatel OT-S319 unlocking? | mobile-phone-service | Easy-Unlocker | 14 | 10-25-2008 18:12 |
Alcatel Ot 320 No Service | haider | BF, BG, TH, BHx Series | 5 | 02-01-2006 18:46 |
