04-30-2009, 16:01 | #1 (permalink) |
No Life Poster Join Date: Apr 2007 Location: SL3 LBF IN Kamoke(Gujranwala)
Member: 481915 Status: Offline Sonork: 100.1604233 Thanks Meter: 476 | Alcatel s210x unlock HERE IS COMPLETE LOG: COM15 selected module v1.32 Device: Alcatel-S210 "advanced chip detection" active Action: unlock Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... finalizing... Boot done Check connection ... Check connection done Set baud ... 203125 Set baud done Check hardware ... flash: 012A7E2A242A00:54000000000000 flash: AMD/Fujitsu std [T 003Fx010000 0004x004000] 4Mb Check hardware done Read data ... reading Alcatel-S210_eeprom_calibration-1... file saved: C:\Program Files\InfinityBox\HModule\Alcatel-S210_eeprom_calibration-1_20090430-194841.80E.bin Read data done Check data ... Check data done Write ... ......... ......... .. flash: 012A7E2A242A00:54000000000000 Write: simlock Write done Finished, time used: 74 sec Remove/Install battery now ! good update infinity team mianlinks |
The Following 3 Users Say Thank You to mianjabbar For This Useful Post: |
04-30-2009, 18:58 | #2 (permalink) | |
Each test report with attached logs is very important for us so we can see how is Infinity-Box software works, what is phone hardware configuration (f.e. flash chip type) and what is possible problems (so we will be able to fix it) and successfully done work. | |
10-06-2014, 08:37 | #4 (permalink) |
No Life Poster Join Date: Mar 2008 Location: FOCSANI Age: 39
Member: 718470 Status: Offline Thanks Meter: 79 | COM100 [VCP7] selected module v1.38 Device: Alcatel-S210 "advanced chip detection" active Action: unlock Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... finalizing... Boot done Check connection ... Check connection done Set baud ... 115200 Set baud done Check hardware ... flash: 012A7E2A242A00:54000000000000 flash: AMD/Fujitsu std [T 003Fx010000 0004x004000] 4Mb Check hardware done Read data ... reading Alcatel-S210_eeprom_calibration-1... file saved: C:\InfinityBox\HModule\Alcatel-S210_eeprom_calibration-1_20141006-103619.80E.bin Read data done Check data ... Check data done Write ... ......... ......... .. flash: 012A7E2A242A00:54000000000000 Write: simlock Write done Finished, time used: 1 min 40 sec Remove/Install battery now ! |
The Following User Says Thank You to gsmiulian For This Useful Post: |
need full flash alcatel s210x | ::. zine .:: | FuriousGold | 10 | 05-16-2011 19:52 |
problem in unlocking Alcatel s210x | robean | Infinity-Box | 2 | 05-07-2009 07:07 |
Alcatel S210X Problem | ..::Angel::.. | Infinity-Box | 10 | 03-16-2009 18:02 |
alcatel ot-s210x unlock problem plz help | asif_ae | Multi-Box | 7 | 12-14-2008 11:25 |
First succsessfully unlocked alcatel s210x with furious gold | Harkishan singh | FuriousGold | 1 | 11-26-2008 13:51 |
