09-15-2009, 14:50 | #1 (permalink) |
Insane Poster Join Date: Feb 2008
Member: 707712 Status: Offline Thanks Meter: 4 | Alcatel s211 can't unlock l tried to unlock alcatel s221 but when is about to finish then it stop. this is the logs thanxs. === log: [9/15/2009 12:58:54 PM] ==== COM3 [VCP4] selected module v1.34 Device: Alcatel-S211 "advanced chip detection" active Action: unlock Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... finalizing... Boot fail error: operation failed Finished, time used: 50 sec Remove/Install battery now ! |
09-15-2009, 18:20 | #3 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Try to repeat operation several times. If it will be no luck it may be that your phone has new CPU type that is not supported yet. |
06-16-2011, 09:03 | #4 (permalink) |
Registered User Join Date: May 2005 Age: 50
Member: 146480 Status: Offline Thanks Meter: 17 | COM6 [VCP0] selected module v1.38 Device: Alcatel-S211 "advanced chip detection" active Action: unlock Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... finalizing... Boot done Check connection ... Check connection done Set baud ... 115200 Set baud done Check hardware ... flash: 012A7E2A242A00:54000000000000 flash: AMD/Fujitsu std [T 003Fx010000 0004x004000] 4Mb Check hardware done Read data ... reading Alcatel-S211_eeprom_calibration-1... file saved: E:\infinity-box shel\alcatal s211\Alcatel-S211_eeprom_calibration-1_20110616-090214.80E.bin Read data done Check data ... Check data done Write ... ......... ......... ... flash: 012A7E2A242A00:54000000000000 Write: simlock Write done Finished, time used: 1 min 41 sec Remove/Install battery now ! |
alcatel s211 cant unlock here is log | software zone | Infinity-Box | 2 | 01-21-2010 08:06 |
Alcatel s211 after unlock no network | goldenploto | Infinity-Box | 5 | 08-18-2009 20:29 |
alcatel s211 sucessfull unlock | bittubansal | Infinity-Box | 5 | 06-29-2009 14:05 |
alcatel s211 sucessfull unlock | bittubansal | Infinity-Box | 1 | 05-12-2009 14:10 |
alcatel e259x can't unlock | alssalafiy | Infinity-Box | 0 | 01-08-2008 17:14 |
