01-21-2009, 21:30 | #2 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,536 | hello! 1. set multimeter to voltage measuring. 2. check bettery voltage, it should be more than 3,7volts 3. set one multimeter probe to some grounded phone part (if you cant find grounded part outside phone- you need to take out small thin wire from negative battery terminal) 4. with second probe touch one by one all phone pins (phone battery attached) (to get better result i would advice to set needle on the end of second probe) memorise pins with voltage between 2,7-2,9volts. those are tx/rx |
I need n95 slidup 2 sim pinout | sureshplaza | Chinese Models & Cloned Phones | 1 | 06-27-2008 05:36 |
i want chaina n95 duel sim pinout | sureshplaza | Infinity-Box | 3 | 04-22-2008 10:06 |
new n95 1 sim pinouts | foxthemene | Infinity-Box | 0 | 03-22-2008 17:53 |
Pinout For Nokia N95 2 Sim 18 pin connector | MarvelXZ | Infinity-Box | 1 | 02-26-2008 00:31 |
N95 Single Sim Pinouts | tajinder | Infinity-Box | 1 | 01-10-2008 12:47 |
