11-21-2009, 14:26 | #1 (permalink) |
No Life Poster Join Date: Nov 2009 Location: INDIA
Member: 1166187 Status: Offline Sonork: 100.1616368 Thanks Meter: 168 | alfatel h2 cant power on module v2.98 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: write NOR flash "smart write" active write: Firmware HUSCKY4_S37_PCB01_GPRS_MT6225_S00.PN-SC_CN_LLNUMLD_234_YYMMDD_CAM_MCPMCP_O__Alfatel-H1_16m_En_Th_Hi.B0M.bin skip: Customization/Language Pack skip: Customization write: Eeprom/ffs HUSCKY4_S27_PCB01_GPRS_MT6225_S00.PN-SC_CN_LLNUMLD_235_YYMMDD_CAM_MCPMCP_O__ffs_2009112 0-121346.B0E.bin ffs/eeprom backup enabled, it may takes several minutes ! Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:7603:000F status: FF boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #02 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #03 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud ... 921600 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 searching rom info... search rom info finished rom info structure: 2nd [enhanced] generation TCL-ID is absent startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.40219C8D.[HUSCKY4_S37_PCB01_GPRS_MT6225_S00.PN-SC_CN_LLNUMLD_234_YYMMDD_CAM_MCPMCP_O.BIN_842A0A66].rpl rom info detection finished device-id: 40219C8D rom info protocol ver: 04 ver. sw 1: HUSCKY4_S37_PCB01_GPRS_MT6225_S00.PN-SC_CN_LLNUMLD_234_YYMMDD_CAM_MCPMCP_O.BIN ver. sw 2: PN-SC_CN_LLNUMLD_234_YYMMDD_CAM_MCPMCP_O, 660A2A84 address offset: 00000000 ffs offset/size: 00E00000/00200000 detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 flash: EC257E25082501:18E59F00000000 checking area [00000000]: 00000000-00FFFFFF... Can't detect ffs/eeprom area Do you want to use standard ffs/eeprom address: 00E00000 ? If you are not sure that standard address is correct: 1. press "NO" and terminate current operation 2. make flash backup for emergency case 3. repeat required operation standard ffs/eeprom address selected by user detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... reading: HUSCKY4_S37_PCB01_GPRS_MT6225_S00.PN-SC_CN_LLNUMLD_234_YYMMDD_CAM_MCPMCP_O__ffs... file saved: C:\Program Files\InfinityBox\ChineseMiracle\HUSCKY4_S37_PCB01 _GPRS_MT6225_S00.PN-SC_CN_LLNUMLD_234_YYMMDD_CAM_MCPMCP_O__ffs_2009112 0-123141.B0E.bin flash: EC257E25082501:18E59F00000000 Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... sec info (fast) detection... searching sec info#1... . search sec info#1 finished startup code area #1 check... startup code area #1 calculation... startup code area #1 fixed detecting startup code area #2... startup code area #2 is absent file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\H USCKY4_S37_PCB01_GPRS_MT6225_S00.PN-SC_CN_LLNUMLD_234_YYMMDD_CAM_MCPMCP_O__system_log_ 40219C8D_842A0A66_20091120-123148.B0X.bin Area: Firmware flash: EC257E25082501:18E59F00000000 Write: Firmware Area: Eeprom/ffs flash: EC257E25082501:18E59F00000000 Write: Eeprom/ffs sec info (fast) detection... searching sec info#1... . search sec info#1 finished Write Done Finalization ... Finalization Done file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\H USCKY4_S37_PCB01_GPRS_MT6225_S00.PN-SC_CN_LLNUMLD_234_YYMMDD_CAM_MCPMCP_O__system_log_ 40219C8D_842A0A66_20091120-123219.B0X.bin Finished, time used: 155 sec Remove/Install battery now ! Last edited by javeed_mp; 11-21-2009 at 14:32. |
11-21-2009, 14:36 | #2 (permalink) |
Member: 1166187 Status: Offline Sonork: 100.1616368 Thanks Meter: 168 | this set was in dead condition so i formated it with safe and compleate mode and flashed with similar version but not succeded.PLEASE HELP. |
3610 cant power on but wit power supply ok! | uwenk98 | Nokia Hardware & Hardware Repair | 4 | 05-08-2004 06:01 |
8310 dead flashing ok but cant power on | mobilemafia | Nokia Hardware & Hardware Repair | 13 | 06-11-2003 23:00 |
S35, after changing PA cant power on | pali | Siemens Hardware Repair Area | 4 | 11-20-2002 10:15 |
c35 cant power on | pali | Siemens Hardware Repair Area | 0 | 09-20-2002 00:32 |
gd90 cant power on after.. | timitiz | Panasonic | 3 | 11-11-2000 20:27 |
