12-07-2009, 09:37 | #1 (permalink) |
No Life Poster Join Date: Nov 2008 Location: Faisalabad pakistan
Member: 900083 Status: Offline Thanks Meter: 601 | To all about unlock t156 new v guide and logs try with different ver like (v100R001B004BC 19SP00) |
12-07-2009, 09:39 | #2 (permalink) |
Member: 900083 Status: Offline Thanks Meter: 601 | Here is logs ver. (v100R001B004BC 19SP00) => module version: 1.72 => operation started: COM3 ==> set_com_port ==> set_baud_rate ==> check_comm_link ==> set_v24_mode ==> set_baud_rate ==> check_comm_link ==> get_ms_id imei: 353081038997600 ==> get_sw_version sw ver: P1.2PU01V01.01 ==> get_sec_version sec ver: 00.31Et(4242) ==> reading... access result: 00 access level: 03 verification result: F06001005612010000010105020503050405040000000000 verification result: F0600100561200FF00010105020503050405000000000000 verification result: F0600100561200FF00010105020503050405000000000000 verification result: F0600100561200FF00010105020503050405000000000000 verification result: F0600100561200FF00010105020503050405000000000000 last error: No errors ==> close_com_port => operation finished Finished, time used: 9 sec Power Off/On phone now ! Not unlocked |
12-07-2009, 09:48 | #3 (permalink) |
Major Poster Join Date: Aug 2008
Member: 847148 Status: Offline Thanks Meter: 0 | i have huwai t156, soft ver v100R001B004C 19SP00, when i try to unlock it, it did not be unlocked. following log is here: => module version: 1.72 => operation started: COM3 ==> set_com_port ==> set_baud_rate ==> check_comm_link ==> set_v24_mode ==> set_baud_rate ==> check_comm_link ==> get_ms_id imei: 353081039485191 ==> get_sw_version sw ver: P1.2PU01V01.01 ==> get_sec_version sec ver: 00.31Et(4242) ==> reading... access result: 00 access level: 03 verification result: F06001005612010000010105020503050405040000000000 verification result: F0600100561200FF00010105020503050405000000000000 verification result: F0600100561200FF00010105020503050405000000000000 verification result: F0600100561200FF00010105020503050405000000000000 verification result: F0600100561200FF00010105020503050405000000000000 last error: No errors ==> close_com_port => operation finished Finished, time used: 6 sec Power Off/On phone now ! pl give me help now i what to do? thanks |
12-07-2009, 09:53 | #4 (permalink) |
Member: 900083 Status: Offline Thanks Meter: 601 | v100R001B004C => module version: 1.72 => operation started: COM3 ==> set_com_port ==> set_baud_rate ==> check_comm_link ==> set_v24_mode ==> set_baud_rate ==> check_comm_link ==> get_ms_id imei: 353081039947570 ==> get_sw_version sw ver: P1.2PU03V01.01 ==> get_sec_version sec ver: 00.3231Et(4242) ==> reading... access result: 00 access level: 03 verification result: F06001005612010000010105020503050405020000000000 verification result: F0600100561200FF00010105020503050405000000000000 verification result: F0600100561200FF00010105020503050405000000000000 verification result: F0600100561200FF00010105020503050405000000000000 verification result: F0600100561200FF00010105020503050405000000000000 last error: No errors ==> close_com_port => operation finished Finished, time used: 8 sec Power Off/On phone now ! NOT unlocked |
12-07-2009, 10:38 | #5 (permalink) |
No Life Poster Join Date: Oct 2005 Location: P A K I S T A N Age: 16
Member: 190344 Status: Offline Thanks Meter: 280 | because it is version 3, sw ver: P1.2PU03V01.01, while i saw here only +ve report with version 1, sw ver: P1.2PU01V01.01,non-counter blocked sets. problems for infinity team. 1. counter blocked sets of all 3 versions. 2. unlocking of version 2 "sw ver: P1.2PU02V01.01" 3. unlocking of version 3. sw ver: P1.2PU03V01.01" |
12-07-2009, 16:10 | #6 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,228 | @/\/\A/\/| DON @malik m. salim you have used old version of Pana01 ! Please, use this latest version with some improvements: http://www.infinity-box.com/download...1_v1.72_v2.rar |
The Following 3 Users Say Thank You to InfinitySupport For This Useful Post: |
12-08-2009, 09:36 | #7 (permalink) | |
Member: 900083 Status: Offline Thanks Meter: 601 | Quote:
k sir i try with that | |
12-08-2009, 12:12 | #8 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,228 | @/\/\A/\/| DON As I can see from your logg, you have tried with previous version (Pana01_v1.71_v1), but latest version has some improvements (Pana01_v1.71_v2) so pls use http://www.infinity-box.com/download...1_v1.72_v2.rar |
12-08-2009, 13:01 | #9 (permalink) | |
sir i tried with this but not unlocked here is logs please sir help me => module version: v. => operation (3) started: COM3 ==> get_dll_version dll version: 38.0i ==> set_com_port ==> set_baud_rate ==> set_v24_mode ==> set_baud_rate ==> check_comm_link ==> get_ms_id imei: 353081039587053 ==> get_sw_version sw ver: P1.2PU01V01.01 ==> get_sec_version sec ver: 00.31Et(4242) ==> get_eep_version eep version: 000C ==> get_eep_revision eep revision: 0000 ==> reading... access result: 00 access level: 03 ==> set required mode... ==> reboot... ==> reading... lock result: 00 lock status: 020A ==> unlock... verification result: F06001005612010000010105020503050405020000000000 verification result: F0600100561200FF00010105020503050405000000000000 verification result: F0600100561200FF00010105020503050405000000000000 verification result: F0600100561200FF00010105020503050405000000000000 verification result: F0600100561200FF00010105020503050405000000000000 ==> restore original mode... last error: No errors => operation finished ==> close_com_port Finished, time used: 19 sec Power Off/On phone now ! | |
12-08-2009, 13:21 | #10 (permalink) |
No Life Poster Join Date: Nov 2007
Member: 624567 Status: Offline Thanks Meter: 256 | => module version: v. => operation (3) started: COM5 ==> get_dll_version dll version: 38.0i ==> set_com_port ==> set_baud_rate ==> set_v24_mode ==> set_baud_rate ==> check_comm_link ==> get_ms_id imei: 353081037913293 ==> get_sw_version sw ver: P1.2PU03V01.01 ==> get_sec_version sec ver: 00.3231Et(4242) ==> get_eep_version eep version: 000C ==> get_eep_revision eep revision: 0000 ==> reading... access result: 00 access level: 03 ==> set required mode... ==> reboot... ==> reading... lock result: 00 lock status: 020A ==> unlock... verification result: F0600100561200FF00050105020503050405000000000000 verification result: F0600100561200FF00050105020503050405000000000000 verification result: F0600100561200FF00050105020503050405000000000000 verification result: F0600100561200FF00050105020503050405000000000000 verification result: F0600100561200FF00050105020503050405000000000000 ==> restore original mode... last error: No errors => operation finished ==> close_com_port Finished, time used: 17 sec Power Off/On phone now ! not succeded....... |
12-08-2009, 13:53 | #11 (permalink) |
No Life Poster Join Date: Dec 2008 Location: some were in my head Age: 42
Member: 922273 Status: Offline Sonork: 100.1583612 Thanks Meter: 119 | repy hi to all members this two version dont work with the latest pana module sw ver: P1.2PU02V01.01, sw ver: P1.2PU03V01.01 |
12-08-2009, 15:41 | #14 (permalink) |
Member: 922273 Status: Offline Sonork: 100.1583612 Thanks Meter: 119 | reply sorry but me too not agree with you....in my contry this two version not work after unlock with the latest pana modul it show on the log unlock but when you put another sim card show blocked counter but with the first version no problem |
12/11/2009 T156 new sec real and FREE support added ! | .:hack3r2k:. | FuriousGold | 83 | 11-15-2009 19:37 |
****All about unlocking all lg3g flash and hight speed**** | EMINEMGSM | LG | 30 | 10-06-2009 19:39 |
About unlocking of new 520,920 and 930 | Tomas | Motorola Old Legacy (EMMI) | 8 | 09-13-1999 02:35 |
