03-27-2009, 13:31 | #1 (permalink) |
No Life Poster Join Date: Oct 2005 Location: P A K I S T A N Age: 16
Member: 190344 Status: Offline Thanks Meter: 280 | how to flash kg 290 ....options disabled i wnt to flsh lg290. it shows lg icon nd then restarts. i have down loaded iles from support. i open lg module 1.38. i have sucessully bcked up ull flash and Eeprom. problem is only Eeprom option is enabled and all other are disabled?? how to flash ths set??? br hamid |
03-27-2009, 13:42 | #2 (permalink) | |
No Life Poster Join Date: Jul 2006 Location: CHINA Age: 34
Member: 320363 Status: Offline Sonork: 100.1578853 Thanks Meter: 3,938 | use any last ......... Quote:
Use any other last lg module 1.3x in 1.39 little bug br.DYNET | |
The Following User Says Thank You to DYNET For This Useful Post: |
03-27-2009, 13:59 | #3 (permalink) |
Member: 190344 Status: Offline Thanks Meter: 280 | ok.i downloaded lg module 1.37 now getting this error COM4 [VCP0] selected module v1.37 Device: LG-KG290 Checking data, wait... advanced flash detection enabled Action: flash write Write: Firmware (code) Skip: File system Write: Alchemy data Skip: Eeprom "smart write" active "keep calibration" active Boot ... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting, wait... Release Power button now ! flash: 89881600010001:89881600000000 flash: Intel Intel/Sharp ext [def 0004x008000 00FFx020000] 32Mb id: 00005283 Boot Done Set baud ... 460800 Set baud Done Check flash ... current eeprom imei: 357456017469951 file saved: C:\Documents and Settings\Administrator\Desktop\eeprom_357456017469 951_LG-KG290_20090327-175446.B1E.bin .............. version: D-9DGDKG290P40 Check flash Done Check space ... Check space Done Check parameters ... Check parameters Done Erase ... Erase Done Write ... Write: Firmware (code) calibration area skipped flash: 89881600010001:89881600000000 error: no any expected answer error: flash write error: 010A0000:00020000 error: no any expected answer error: flash write error: 010A0000:00020000 error: no any expected answer error: flash write error: 010A0000:00020000 error: no any expected answer error: flash write error: 010A0000:00020000 Write Fail Finished, time used: 170 sec Remove/Install battery now ! |
03-27-2009, 14:39 | #4 (permalink) |
Member: 190344 Status: Offline Thanks Meter: 280 | the set has become completely dead. i want to revive it. i wrote all the backed up erproms but scuceess. there were two files save wheni backed up the full flash. 1. D-9DGDKG290P40_part_1_of_2_357456017469951_LG-KG290_20090327-155222.B1X 2. D-9DGDKG290P40_part_2_of_2_357456017469951_LG-KG290_20090327-160055.B1X in which window(file system.eprom,Alchemy data, ffirmware code) should i select 1 and 2 files |
03-27-2009, 15:42 | #5 (permalink) |
Member: 190344 Status: Offline Thanks Meter: 280 | with LG module 1.25A i could write one file firmware but failed in alchymy data now after writing one file kg290 logo comes once then set off. COM4 [VCP0] selected Device: LG KG290 Checking data, wait... advanced flash detection active Action: flash write Write: Firmware (code) Skip: File system Write: Alchemy data Skip: Eeprom "smart write" enabled "keep calibration" enabled Boot... Phone must be POWERED-OFF ! Press and HOLD Power button ! Connecting, wait... Release Power button ! flash: 89881600010001:89881600000000 flash: Intel Intel/Sharp ext [def 0004x008000 00FFx020000] 32Mb id: 00005283 Boot Done Set baud... 921600 Set baud Done Check flash... current eeprom imei: 357456017469951 file saved: C:\Documents and Settings\Administrator\Desktop\backup_eeprom_35745 6017469951_LG KG290_20090327-192606.B1E.bin . . . . . . . . . . . . . . version: D-9DGDKG290P40 Check flash Done Check space... Check space Done Check parameters... Check parameters Done Erase... Erase Done Write... Write: Firmware (code) calibration area skipped flash: 89881600010001:89881600000000 Write: Alchemy data flash: 90009000900090:90909000000000 flash: 90009000900090:90909000000000 error: wrong write first sector at 0x00000000 Write Fail error: wrong answer[C1] Finished, time used: 771 sec Remove/Install battery now ! |
03-27-2009, 16:47 | #6 (permalink) | |
No Life Poster Join Date: Sep 2006
Member: 343326 Status: Offline Thanks Meter: 1,463 | Quote:
Code: error: no any expected answer error: flash write error: 010A0000:00020000 | |
03-28-2009, 05:56 | #9 (permalink) |
Member: 190344 Status: Offline Thanks Meter: 280 | ther is no ffs option in Lg module A 1.37 how to write back these two backed up files there were two files save wheni backed up the full flash. 1. D-9DGDKG290P40_part_1_of_2_357456017469951_LG-KG290_20090327-155222.B1X 2. D-9DGDKG290P40_part_2_of_2_357456017469951_LG-KG290_20090327-160055.B1X |
05-25-2009, 23:34 | #10 (permalink) |
Crazy Poster Join Date: Apr 2006 Location: Kashmir
Member: 255140 Status: Offline Thanks Meter: 9 | LG KG290 hang with startup logo format ffs with LG-KG291i your mobile is 100% working BY KH NAEEM COM4 selected module v1.38 Device: LG-KG291i Checking data, wait... advanced flash detection enabled Action: reset Boot ... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting, wait... Release Power button now ! flash: 89881600010001:89881600000000 flash: Intel Intel/Sharp ext [def 0004x008000 00FFx020000] 32Mb id: 00005283 Boot Done Set baud ... 115200 Set baud Done Check flash ... current eeprom imei: 357456017049241 file saved: C:\Program Files\InfinityBox\LGA\eeprom_357456017049241_LG-KG291i_20090526-040349.B1E.bin .................................................. .............. reading _eeprom-ffs_357456017049241... file saved: C:\Program Files\InfinityBox\LGA\_eeprom-ffs_357456017049241_LG-KG291i_20090526-042156.B1E.bin Check flash Done Check space ... Check space Done Check parameters ... Check parameters Done Erase ... Erase Done Write ... Write Done Finished, time used: 1421 sec Remove/Install battery now ! BY:KH NAEEM |
how to flash s5233A (flash option disable) | nakshatra | NSPRO | 8 | 11-01-2009 05:14 |
how to flash kg 270 on infinity | udenx | LG | 0 | 04-02-2009 09:02 |
How to Flash KG-800 with infinity | abellcell | Infinity-Box | 0 | 06-09-2008 05:54 |
how to unlock kg 290 | fonecorner | FuriousGold | 2 | 01-21-2008 20:47 |
how to unlock kg 290 | fonecorner | FuriousGold | 2 | 01-21-2008 18:41 |
