12-29-2016, 15:47 | #1 (permalink) |
No Life Poster Join Date: Dec 2004 Location: Uganda Age: 45
Member: 96478 Status: Offline Sonork: 100.1674604 Thanks Meter: 1,420 | Allow Cm2 softwares 1* Allow Cm2 software to use all non occupied usb ports. : You cant use CM2 After,when you already opened another Tool doing its Operations. Eg. IF MTK SPF FLASHING,You want to Read pattern of another Phone using MtkCM2(Not Possible until you disconnect phone from Mtk Spf tool) 2* Read Extended info: Add Read Emmc Status. 3* Add Read password/Pins/patterns created using apps,like Du-privacylock ,APP-LOCK Etc.... Or Disable such Apps WITHOUT FORMATING PHONE Because their passwords are not accessible by CM2 NOW. BEST Regards |
12-29-2016, 18:43 | #2 (permalink) |
No Life Poster Join Date: Dec 2013 Location: India
Member: 2082450 Status: Offline Thanks Meter: 1,454 | 1- I think not possible, as software may conflict of which port to taken into action to perform the chosen operation.... But, not sure... 2 - There is a other button exists for such problem. Well, but supporting your idea, there can be a check box to select the operation to do on next. 3- Doesn't 'reset privacy lock' help with that?? |
12-29-2016, 19:45 | #3 (permalink) | |
Member: 96478 Status: Offline Sonork: 100.1674604 Thanks Meter: 1,420 | Quote:
2-I know that button but to simplify,during Read info helps alot to know the status,instead of wasting time flashing Readonly Emmc. 3- Passwords/pin etc.. Set by Downloaded apps cannot be detected by Cm2(it says "Patterns not Set") | |
12-30-2016, 19:29 | #4 (permalink) | |
No Life Poster Join Date: Apr 2009 Location: Inside Infinity
Member: 1010626 Status: Offline Sonork: using fb Thanks Meter: 735 | Quote:
3) we can do it app manager we can uninstall any app like 3rd party security app | |
