Old 04-21-2010, 07:14   #1 (permalink)
nadirghazi's Avatar
Member: 779665
Sonork: 100.1581784
Thanks Meter: 492
always got problem when i do flashing plz help
Hi i got chines with restart problem 1st i formated but phone doesnt solve problem then i read flash and start flashing with new firmware
M7048__ZHC_1_8_L15_PCB01_GPRS_MT6223P_S00.KABM7048 ZH_1_00_519.BIN
here is flashing Log
COM6 [VCP0] selected
module v3.08
Device: Autodetect 6205-6227 NOR
Checking data, wait...
Action: write flash
"smart write" active
write: Firmware
M7048__ZHC_1_8_L15_PCB01_GPRS_MT6223P_S00.KABM7048 ZH_1_00_519_16m_En_Fr_Hi_Pt_Ar.B0M.bin
skip: Customization/Language Pack
skip: Customization
skip: Eeprom/ffs
ffs/eeprom backup enabled, it may takes several minutes !
====> Boot ...
19200 fixed
Connecting, wait...
Initializing [6223:8A05:8A00]...
CPU: MT6223
high speed boot On
chip: 0011:7EBD:000C
status: FF
boot packet size: 0400
Release Power button now !
Boot Done
====> Initialize ...
flash: 2088C4FFFFFFFF:2088C400000000
flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb
otp offset: 00FE0000
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
number of flash chip/regions detected: 04/01
Initialize Done
====> Set baud ...
460800
Set baud Done
====> Initialize bootcode ...
Initialize bootcode Done
====> Check firmware integrity ...
device parameters detection in progress...
it's time to stop: 2B0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
usb bootloader detect...
usb bootloader detect (phase #2)...
usb bootloader (chip) is absent
searching rom info...
search rom info finished
rom info structure: 2nd [enhanced] generation
TCL-ID is absent
startup code area #1 is Ok
startup code area #1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.D239349C.[M705DHZ_PCB01_GPRS_MT6223_S00.KAAM705DHZ_2_02_522. BIN_E23D2C47].rpl
rom info detection finished
New firmware detected (v.3.08, database date: unknown):
This firmware is missing in support area. If this phone is good and working:
- download latest software from support area and try again, probably this firmware already supported in latest software
- make "Read full flash" operation
- send flash backup files to support: [email protected] or upload files to RapidShare: 1-CLICK Web hosting - Easy Filehosting or 4shared.com - free file sharing and storage
- include in your e-mail full text from phone back label (phone name etc.)
device-id: D239349C
rom info ver: 05
sw version: M705DHZ_PCB01_GPRS_MT6223_S00.KAAM705DHZ_2_02_522. BIN
project-id: KAAM705DHZ_2.02.522, 472C3DE2
code offset: 00000000
ffs offset/size [01]: 00E00000/00200000
TCL-ID is absent
detecting ffs/eeprom area in 1 chip(s)...
standard ffs/eeprom offset detected: 00E00000
standard ffs/eeprom offset confirmed: 00E00000
detecting ffs/eeprom size...
ffs/eeprom size: 00200000
ffs/eeprom chip: 00
ffs/eeprom area: 00000000:00E00000-00FFFFFF
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
Check firmware integrity Done
====> Check firmware content ...
Check firmware content Done
====> Backup required data ...
reading: M705DHZ_PCB01_GPRS_MT6223_S00.KAAM705DHZ_2_02_522_ _ffs...
file saved: C:\Program Files\InfinityBox\ChineseMiracle\M705DHZ_PCB01_GPR S_MT6223_S00.KAAM705DHZ_2_02_522__ffs_20100420-220514.B0E.bin
Backup required data Done
====> Patch required data ...
Patch required data Done
====> Special operation ...
Special operation Done
====> Write ...
sec info (fast) detection...
usb bootloader (file) is absent
startup code area #1 check...
startup code area #1 fixed
detecting startup code area #2...
startup code area #2 is absent
file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\M 705DHZ_PCB01_GPRS_MT6223_S00.KAAM705DHZ_2_02_522__ system_log_D239349C_E23D2C47_20100420-220933.B0X.bin
Area: Firmware
Write: Firmware
Write Done
====> Finalization ...
Finalization Done
file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\M 705DHZ_PCB01_GPRS_MT6223_S00.KAAM705DHZ_2_02_522__ system_log_D239349C_E23D2C47_20100420-221833.B0X.bin
Finished, time used: 15 min 25 sec
Remove/Install battery now !
then i flashing with its orignall firmware
705DHZ_PCB01_GPRS_MT6223_S00.KAAM705DHZ_2_02_522__ fullflash_20100419-065437.B0M.bin
now phone turn on with blank lcd plz help
Old 04-21-2010, 21:47   #2 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
does this backup was taken from working phone or it was already with "white screen"?
Old 04-22-2010, 06:35   #3 (permalink)
nadirghazi's Avatar
Member: 779665
Sonork: 100.1581784
Thanks Meter: 492
=InfinityHelp;5745162]hello!
yes it was working phone with restart problem
Old 04-22-2010, 21:22   #4 (permalink)
Member: 148515
hello!
very strange situation.
can you find same version working phone to read out backup?
Old 04-23-2010, 15:27   #5 (permalink)
nadirghazi's Avatar
Member: 779665
Sonork: 100.1581784
Thanks Meter: 492
=InfinityHelp;5750021]hello!
Yes i am confused that i have orignal back up then why its not working?
any way its very hard for me to find same version.
I suggest to give idea to Infinity Team to do not make hard Firmwares for Chines phones because i noticed mostly users dont know before flashing that they must need to get 1st back up for emergency cases i have also about 10 dead Units.
so i wanted that make firmware like oridany firmwares ''WRITE FLASH'' set become turn on.
I can hope infinity team will think on my opnion and i am sure they will work thanks
Old 04-23-2010, 16:55   #6 (permalink)
nadirghazi's Avatar
Member: 779665
Sonork: 100.1581784
Thanks Meter: 492
Phone is on with white screen,on LCD it shows FATEL ERORR..
Old 04-23-2010, 21:33   #7 (permalink)
Member: 148515
hello!
we dont show "backup advice message" to each operation because they are very annoying
i guess everyone has learned this from our FAQ section or documents from Infinity folder.
at least by own experience, after killing 1 phone.
anyway, in your case backup became damaged. I dont have any idea how this happend.
but now we must search for same firmware to rescue it.
please let me know full phone name, becuase i cant find nothing by this software version
Old 04-25-2010, 10:37   #8 (permalink)
nadirghazi's Avatar
Member: 779665
Sonork: 100.1581784
Thanks Meter: 492
Thanks alot
X MOBILE X1680I
This is copy of nokia 1680 phone
Old 04-25-2010, 15:57   #9 (permalink)
Member: 148515
hello!
sorry, cant find by phone model name either
Old 04-27-2010, 14:34   #10 (permalink)
nadirghazi's Avatar
Member: 779665
Sonork: 100.1581784
Thanks Meter: 492
=InfinityHelp;5761077]hello!
Ok thanks alot for ur kind Help
How can I do a Welcome note for my 6110 a dosn't have any one ? Viper Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 06-27-2015 11:57
Page generated in 0.23628 seconds with 9 queries
