05-12-2015, 09:23 | #1 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Another First :) MT6732 Android 5.0 : Factory FW Read / Flash I even not have idea, how set USB debug in 5.x, because it not need. With CM2 you can do it. Rwad Factory FW : Code: Operation : Read Flash [ v1.20 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 4 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6752 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6732|MT6752_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 150100523832314D42004CD7D00B222B DA Stat : v4.2 on BBID : 0x8F DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : BM128 [eMMC] : FLASH_CID : 150100523832314D42004CD7D00B222B [eMMC] : FLASH_LEN : 0x00000003A3E00000 INT RAM : 0x00020000 EXT RAM : 0x80000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Conent now ... Brand : alps ProdName : k01q_h ProdModel : k01q_h Device : k01q_h AndroidVer: 5.0 MTKxCPU : MT6752 MTKxPRJ : ALPS.L0.MP6.V3.20_NB6752.LWT.CU_P2 MediaTek MT67xx [x64] : Normalize settings Ok [Read Ok] : preloader_k01q_e.bin [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : secro.img [Read Ok] : logo.bin [Read Ok] : custom.img [Read Ok] : tz1.img [Read Ok] : tz2.img [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : userdata.img [ScatCFG] : MT6752 / V1.1.2 / k01q_e / EMMC FW Size : 1991 MiB Scatter saved to : E:\MT6752__alps__k01q_h__k01q_h__5.0__ALPS.L0.MP6.V3.20_NB6752.LWT.CU_P2\ All done! Done! Elapsed: 00:08:42 Reconnect Power/Cable! Code: Operation : Flash [ v1.20 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 4 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6752 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6732|MT6752_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 150100523832314D42004CD7D00B222B DA Stat : v4.2 on BBID : 0x8F DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : BM128 [eMMC] : FLASH_CID : 150100523832314D42004CD7D00B222B [eMMC] : FLASH_LEN : 0x00000003A3E00000 INT RAM : 0x00020000 EXT RAM : 0x80000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6752 , Project : k01q_e , Storage : EMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Enabled BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Check eMMC compatibility BL : eMMC supported by BootLoader! BL : Flash Pre-Erase Total blocks to Erase : 1 Erase : 0x0000000001C80000-0x00000003A1100000 Flash Pre-Erase Done, time used : 00:00:12 SecCfg Passed , 1799 BMT remark not need. Will skip Sending Preloader ... Use : preloader_k01q_e.bin Preloader Sent , Init passed SecCfg Passed , 1799 PartCount : 0013 Update PMT by user request Repartition Done! Processing : Flash Write Flash now : LK Image Flash Ok Flash now : BOOT Image Flash Ok Flash now : RECOVERY Image Flash Ok Flash now : SECRO Image Flash Ok Flash now : LOGO Image Flash Ok Flash now : CUSTOM Image Flash Ok Flash now : TEE1 Image Flash Ok Flash now : TEE2 Image Flash Ok Flash now : SYSTEM Image Flash Ok Flash now : CACHE Image Flash Ok Flash now : USERDATA Image Flash Ok Flash Write Done, time used : 00:03:39 Processing : Verify Verify Passed : LK Verify Passed : BOOT Verify Passed : RECOVERY Verify Passed : SECRO Verify Passed : LOGO Verify Passed : CUSTOM Verify Passed : TEE1 Verify Passed : TEE2 Verify Passed : SYSTEM Verify Passed : CACHE Verify Passed : USERDATA Data Verify Done, time used : 00:01:10 Update Mirror PMT Update Done! Update RomInfo done Done! Elapsed: 00:05:16 Reconnect Power/Cable! |
05-12-2015, 10:07 | #2 (permalink) | |
Freak Poster Join Date: Oct 2011 Location: Ukraine
Member: 1671331 Status: Offline Thanks Meter: 60 | Chinese Miracle-2 MTK v1.20 Quote:
The Following 2 Users Say Thank You to Aprilia31 For This Useful Post: |
