05-11-2010, 11:47 | #1 (permalink) |
No Life Poster Join Date: May 2010 Location: In The World
Member: 1294926 Status: Offline Sonork: 100.1608183 Thanks Meter: 126 | another one....plz what's wrong Release Power button now ! Phone detected, wait... warning: can't read software version, probably unknown firmware detecting structure #2... 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31error: detection failed (32 tries), read flash and send to support connection lost error: operation failed ! Finished, time used: 2 min 36 sec Remove/Install battery now ! |
05-11-2010, 18:16 | #3 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | What operation you have tried to do ? What was "ChineseMiracle" software version ? |
05-11-2010, 18:57 | #5 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | This phone has damaged flash chip, so you must make correct name for this thread "can not repair damaged hardware with any software operations". |
05-11-2010, 21:07 | #6 (permalink) |
Member: 1294926 Status: Offline Sonork: 100.1608183 Thanks Meter: 126 | but why it can read full flash from the handset ?? and why it formate it using the format ffs with complete mode . and the phone become now dead (befor it restart itself). |
05-12-2010, 20:05 | #7 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! lets start from beggining: 1. what is phone full model name? 2. what is phone original software version? 3. provide here log of Format FFS complete, after which it went dead. original software version, same as Format log you can find in operatio.log file, which is loacted in same directory where Chinese Miracle is. Open it with any text editor (f.e. notepad) and scrool it from up from end. find needed operation and post here log |
05-13-2010, 08:30 | #8 (permalink) | |
Member: 1294926 Status: Offline Sonork: 100.1608183 Thanks Meter: 126 | Quote:
COM5 [VCP0] selected module v3.13 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: reset settings ("format ffs") ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:B203:0008 status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 2088C4BFFFBFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 detecting chip #01 in region #00... flash: 2088C4BFFFBFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 detecting chip #02 in region #00... flash: 2088C4BFFFBFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 detecting chip #03 in region #00... flash: 2088C4BFFFBFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: 2088C4BFFFBFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 detecting chip #01 in region #00... flash: 2088C4BFFFBFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 it's time to stop: 18B09FA518B09FA518B09FA518B09FA518B09FA518B09FA5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... . search rom info finished searching rom info... . search rom info finished warning: rom info information not found, possible reasons: - old firmware type w/o rom info information - empty (completely or partially erased) flash chip - damaged firmware - damaged hardware (bad soldered or damaged flash chip) > if phone works fine just ignore this warning < detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset assigned: 00E00000 flash: 2088C4BFFFBFFF:2088C400000000 checking area [00000000]: 00080000-00FFFFFF... ffs/eeprom found near: 008A0000 Detected ffs/eeprom address is non-standard: 008A0000 Posible reasons: 1. ffs/eeprom is Ok but address is non-standard 2. ffs/eeprom is damaged and can't be detected 3. ffs/eeprom is Ok but detected incorrectly (f.e. unknown ffs/eeprom structure) If you are not sure that detected address is correct: 1. press "NO" (and select standard address or terminate current operation) 2. make full flash backup for emergency case 3. repeat required operation Are you sure that detected ffs/eeprom address is correct ? autodetected ffs/eeprom address confirmed by user: 008A0000 detecting ffs/eeprom size... ffs/eeprom size: 00760000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:008A0000-00FFFFFF sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: _ffs... file saved: C:\Documents and Settings\Administrateur\Bureau\_ffs_20100511-105938.B0E.bin flash: 2088C4BFFFBFFF:2088C400000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 2088C4BFFFBFFF:2088C400000000 Finalization Done Finished, time used: 15 min 15 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! | |
05-13-2010, 21:04 | #9 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! this is log of formating already dead phone. i am asking to find in operation.log FIRST operation with this phone. you can also do this by date/time stamp if you remmeber it. also why my question regarding full phone model name is ignored? |
Plz help with unlock NOKIA 6110 2lock | henr | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 11-29-1999 22:29 |
Does any one know how to program the ESN number with nokia 6120? | Bert | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 11-02-1999 10:45 |
no one can unlock 6110 05.40 25-5-99 | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 09-22-1999 08:03 |
Copy from one 6110 to another | Leif Nielsen | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-10-1999 22:36 |
