02-15-2009, 12:11 | #1 (permalink) |
Freak Poster Join Date: Jun 2008 Location: +92 345 5313170
Member: 802214 Status: Offline Sonork: 100.1573572 Thanks Meter: 95 | any salutation this probalam???? but phone is show this probalam COM9 [VCP0] selected module v1.62 Device: LG-KG288 Checking data, wait... Action: unlock direct unlock method #2 (Airtel etc.) Boot ... loader: standard type: 4 Press and HOLD Power button now ! loading... next part... error: can't run main loader: try to use another loader type Finished, time used: 4 sec Remove/Install battery now ! |
02-15-2009, 13:18 | #4 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | @.::adnangsm::. Did you tried to flash phone ? Are you sure that phone hardware is not damaged ? |
11-17-2009, 15:09 | #6 (permalink) | |
How to write flash (upgrade/downgrade firmware, change language): 1. connect cable from box to device 2. run "Infinity-Box Shell" software 3. select required model 4. run required software module 5. select required model (if need) 6. go to software "Settings" page and select COM port 7. go to software "Flash" page and load required files 8. press "Write" button and follow instruction given by software How to read flash: 1. connect cable from box to device 2. run "Infinity-Box Shell" software 3. select required model 4. run required software module 5. select required model (if need) 6. go to software "Settings" page and select COM port 7. go to software "Service" page 8. press "Read flash" (or "Read full flash") button and follow instruction given by software How to unlock (remove sp-lock, provider lock etc.): 1. connect cable from box to device 2. run "Infinity-Box Shell" software 3. select required model 4. run required software module 5. select required model (if need) 6. go to software "Settings" page and select COM port 7. go to software "Service" page 8. press "SP-Unlock" button and follow instruction given by software How to reset/format ffs (reset setting to default values, repair freez/restart etc.): - at first try to make "safe format" (if this option exist) - if "safe" option is not works try to make "complete" format (if this option exist) 1. connect cable from box to device 2. run "Infinity-Box Shell" software 3. select required model 4. run required software module 5. select required model (if need) 6. go to software "Settings" page and select COM port 7. go to software "Service" page 8. select format mode "safe" or "complete" (if mode is available) 9. press "Reset" or "Format" button and follow instruction given by software | |
K800 keypad problem any salution | pkghosh1 | Sony Ericsson Hardware Repair | 20 | 12-11-2013 12:23 |
is there any salution for this | rpssana | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 6 | 02-25-2010 13:23 |
any salution of imie 1234? in cyclon | pakmobiles | Cyclonebox | 1 | 06-01-2009 18:01 |
again & again & again posting but not get any salution yet | umair666 | Sony Ericsson Hardware Repair | 4 | 04-18-2009 08:55 |
any1 herehelp plz tell me 5th time posting but still not any salution ???? | umair666 | Sony Ericsson Hardware Repair | 2 | 02-23-2009 09:24 |
