Old 04-07-2009, 13:15   #1 (permalink)
biochemistali's Avatar
Member: 190344
Thanks Meter: 280
nokia copy 5220....need help
dear sir,
case:
set nokia 5220 comes in the problem tht it was not opening the menu.
after format it can open the menu.
after ormat it was on emergency call. duing this state with out sim it cn make call 112.
i epaired imei. still emergency.
i formt the whole chip. set was dead after that.
by writing full back and eeprom set was on but same situation(its imei number is made ok, it can call with out simm to 112 but with emergency.
an important thing from menu..setting. phone setting..the option network selection has disappererd.
this option is no where in the phone.
phone contin the flash file RHY25_06B_PCB01_GPRS_MT6225_S00.A510_SM_K5L2731_IL I9221_V01.BIN]
the pin out are also attached to be added for future pin out updtes.
is there any way to make it working.
br
hamid
The Following User Says Thank You to biochemistali For This Useful Post:
Old 04-07-2009, 13:58   #2 (permalink)
Member: 190344
Thanks Meter: 280
the flash log is
COM16 [Serial2] selected
module v2.79
Device: Autodetect 6205-6227 NOR
Checking data, wait...
Action: write NOR flash
"smart write" active
write: Firmware
skip: Customization/Language Pack
skip: Customization
skip: Eeprom/ffs
Boot ...
19200 fixed
Connecting, wait...
Initializing [6225:8A03:8A00]...
CPU: MT6225
high speed boot On
chip: 0001:B403:0009
status: FF
boot packet size: 0400
Release Power button now !
Boot Done
Initialize ...
flash: EC257E25082501:18E59F00000000
flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
number of flash chip/regions detected: 04/01
Initialize Done
Set baud ...
460800
Set baud Done
Initialize bootcode ...
Initialize bootcode Done
Check firmware integrity ...
detect device identification#1...
detection phase #1...
detect device identification#1 finished
identification#1 structure: 2nd [enhanced] generation
security area (code #1) is damaged, recalculation required
identification#1 detection finished
device-id: 90613C6C
identification#1 protocol ver: 04
ver. sw 1: RHY25_06B_PCB01_GPRS_MT6225_S00.A510_SM_K5L2731_IL I9221_V01.BIN
ver. sw 2: A510_SM_K5L2731_ILI9221_V01, 95366C84
ffs offset/size: 00E00000/00200000
detect device identification#2...
detect device identification#2 finished
Check firmware integrity Done
Check firmware content ...
Check firmware content Done
Backup required data ...
Backup required data Done
Patch required data ...
Patch required data Done
Special operation ...
Special operation Done
Write ...
warning: rpl file not found: C:\Program Files\InfinityBox\ChineseMiracle\id.90613C6C.[RHY25_06B_PCB01_GPRS_MT6225_S00.A510_SM_K5L2731_IL I9221_V01.BIN_7B93C96A].rpl
warning: rpl file not found: C:\Program Files\InfinityBox\ChineseMiracle\id.90613C6C._RHY2 5_06B_PCB01_GPRS_MT6225_S00.A510_SM_K5L2731_ILI922 1_V01.BIN_7B93C96A_.rpl
security area (code #1) backup loaded
security area (code #1) calculation...
done
detecting security area (code #2)...
security area (code #2) is absent
Area: Firmware
Write: Firmware
Write Done
Finalization ...
Finalization Done
Finished, time used: 593 sec
Remove/Install battery now !
Old 04-20-2009, 07:54   #3 (permalink)
Member: 190344
Thanks Meter: 280
5220 file avai;able if neede
i got full back up 5220 from a working phone available if needed.
complete description of file is
br
hamid
Old 04-20-2009, 08:29   #4 (permalink)
Member: 130995
Thanks Meter: 35,227
br
hamid
Hello,
Please, send this full flash backup to [email protected]
Thank you !
The Following User Says Thank You to InfinitySupport For This Useful Post:
Old 04-20-2009, 10:06   #5 (permalink)
Member: 190344
Thanks Meter: 280
i sent it please check mail,because using yahoomail some time sent message shown but attachment not recach.
br
hamid
Old 04-20-2009, 20:32   #6 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
who was sender or what subject it has?
Old 04-21-2009, 04:39   #7 (permalink)
Member: 190344
Thanks Meter: 280
sender: hamid ali(biochemistali) from pakistan
subject: sorry i cannot recall exactly
Old 04-21-2009, 18:17   #8 (permalink)
Member: 148515
hello!
yes, your email is recieved, thank you!!!
siemens CX75 cant copy anything... need help haloman Siemens Hardware Repair Area 2 03-13-2006 09:09
nokia 3100, i need help!!! shurubelul UFS2 + UFS3-Tornadoflasher 2 08-02-2005 14:30
Nokia 3220 flashing..need help! david69 Griffin 0 02-13-2005 21:01
NOKIA 7110 SOFTWARE, NEED HELP !!PLZ. PopeY Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 10-01-2000 07:56
Page generated in 0.18404 seconds with 10 queries
