01-22-2009, 05:43 | #1 (permalink) |
Freak Poster Join Date: Jan 2007 Location: ALGERIA
Member: 431529 Status: Offline Thanks Meter: 18 | Touch screen calibration failed i have some pieces of CECT i658 here is picture http://rapidshare.com/files/187469386/IMAGE_00027.jpg i uploaded its fullflash http://rapidshare.com/files/18746319...033231.B0M.bin please infinity team when i format ffs/eep complet phone dies i restore eeprom from backup and format safe after i calibrate screen allways i fail even i change mode whats the problem and how to solve PS : its pinout RX 13 TX 11 thanx for support |
01-22-2009, 06:28 | #2 (permalink) |
Member: 431529 Status: Offline Thanks Meter: 18 | here is on piece of nokia N81 witch i succeded to calibrate its screen using infinity @infinity team here is its fullflash http://rapidshare.com/files/18747640...030134.B0M.bin Rx 13 TX 11 thanx infinity |
01-24-2009, 05:32 | #4 (permalink) |
Member: 431529 Status: Offline Thanks Meter: 18 | @infinity team here is log COM7 [VCP0] selected module v2.74 Action: touchscreen calibration mode: 3 Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:4E03:0009 Connecting, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E03 Date: 2006.06.14 Version: 1.0 Version: E880_EVTST.01.0_25S00 Version: EVEN25_HW detecting structure #2... 0 done 44 byte(s) read imei: 35755600009661 connection Ok detecting structure #5 (mode-4)... 0 1 2 3 4 5 6 7 8 9error: detection failed (10 tries) What to do: Try another calibration method, if still no luck: 1. make full flash backup for emergency case 2. make "format ffs" 3. Power-On phone 4. Power-Off phone by "Power" button (do NOT remove battery) 5. Repeat "Calibration" operation again 6. if still no luck read full flash and send to support with subject: touchscreen calibration failed error: can't read required data error: operation failed ! Finished, time used: 13 sec Remove/Install battery now ! WARNING ! Settings will be cleared, user data erased, Imei set to default value ! Make flash backup before this procedure ! |
01-26-2009, 01:14 | #6 (permalink) |
Member: 431529 Status: Offline Thanks Meter: 18 | the LCD is broken otherwise wy use box to calibrate it i succeded to calibrate one chinese phone with broken lcd before but this phone i dont know Whats wrong with it |
01-27-2009, 04:45 | #8 (permalink) |
Member: 431529 Status: Offline Thanks Meter: 18 | FINALLY I SUCCEDED TO PASS WITH LATEST VERSION BUT AS ALLWAYS SCREEN IS NOT CALIBRATED AND PHONE ASKS TO CALIBRATE SCREEN HERE IS LOG COM7 [VCP0] selected module v2.75 Action: touchscreen calibration mode: 3 Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:4E03:0009 Connecting, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E03 Date: 2006.06.14 Version: 1.0 Version: E880_EVTST.01.0_25S00 Version: EVEN25_HW detecting structure #2... 0 done 44 byte(s) read imei: 35755600009661 connection Ok detecting structure #5 (mode-4)... 0 1 2 3 done 167 byte(s) read writing data... verification... verification Ok Finished, time used: 10 sec Remove/Install battery now ! WHAT ELSE INFINITY |
01-27-2009, 21:13 | #9 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, We will double check what may be wrong. Do you see any changes at touchscreen after calibration process or it's the same as before calibration ? |
Touch Screen calibration Fail | KK Mobile | SpiderMan | 0 | 02-08-2010 08:32 |
touch screen calibrate solution | anmol1gupta | SpiderMan | 4 | 05-25-2009 04:08 |
Sigmatel S3 Touch screen Calibration Solution | Sandeep9669 | Infinity-Box | 2 | 07-08-2008 06:07 |
n95 china phone hang and touch screen calibration repaired by infinity | megatech10 | Infinity-Box | 0 | 05-28-2008 09:28 |
