06-26-2008, 22:39 | #1 (permalink) |
No Life Poster Join Date: May 2005 Age: 40
Member: 146708 Status: Offline Sonork: 100.108221 Thanks Meter: 1,603 | General Mobile LT X3 Totaly Dead.. hi all and supprter.. customer told me... "when i was transferring music phone power off suddenly"... i tried flash file.. but not success.. and now i think phone i now totaly dead... pls check the log sir.. what is the right flash file..? or what is the solution..? b.r. Code: COM26 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: read/check detailed information Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6205:8B00]... CPU: MT6205 high speed boot enabled boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 01227E22022201:16F83C00000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #01 in region #00... flash: 01227E22022201:16F83C00000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #02 in region #00... flash: 01227E22022201:16F83C00000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #03 in region #00... flash: 01227E22022201:16F83C00000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud... 460800 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: 01227E22022201:16F83C00000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #01 in region #00... flash: 01227E22022201:16F83C00000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb it's time to stop: 166F3CF864895FB9EBE7C2665679CBE317986CE79F672099 number of flash chip/regions detected: 01/01 total flash region size: 00800000 detect device identification#1... detection phase #1... . detection phase #2... ................................................................................................................................ warning: identification#1 information not found, possible reasons: .old firmware type w/o identification#1 data .damaged firmware .damaged hardware if phone works fine just ignore this warning detect device identification#1 finished detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset assigned: 00700000 flash: 01227E22022201:16F83C00000000 checking area[00000000]: 00000000-007FFFFF... eeprom/ffs found near: 00600000 Detected eeprom/ffs address is non-standard: 00600000 Posible reasons: 1. eeprom is Ok but address is non-standard 2. eeprom damaged and can't be detected 3. eeprom is Ok but detected incorrectly (f.e. unknown eeprom structure) If you are not sure that detected address is correct: 1. press "NO" (and select standard address or terminate current operation) 2. make flash backup for emergency case 3. repeat required operation Are you sure that detected eeprom address is correct ? autodetected eeprom/ffs address[00600000] confirmed by user detecting eeprom/ffs size... eeprom/ffs size: 00200000 ffs chip: 00 eeprom/ffs area: 00000000:00600000-007FFFFF detecting ffs structure pass 1... ........................ can't detect fat record name location ffs element #1 detection failed detecting ffs structure pass 2... ........................ can't detect fat record name location ffs element #2 detection failed Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... Finished, time used: 54 sec Remove/Install battery now ! |
general mobile dst11 LT x3 secont imei problem fixed | yargich | Infinity-Box | 0 | 05-27-2009 07:34 |
General Mobil DST11, Tinno DX11, LT X3 pinout, firmware upgrade and write 2 IMEI Help | odiseus | Infinity-Box | 5 | 12-18-2008 19:02 |
Need Flash File for GENERAL MOBILE DST11 or LT-X3 or gplus 2000 | toroslu | Chinese Cocktail | 0 | 02-18-2008 23:06 |
Need Flash File for GENERAL MOBILE DST11 or LT-X3 | toroslu | Multi-Box | 0 | 02-18-2008 21:52 |
LT X3 english manual | sixpack | Off Topic Zone | 0 | 12-23-2007 16:59 |
