04-09-2008, 22:35 | #1 (permalink) |
Junior Member Join Date: Nov 2005
Member: 196693 Status: Offline Thanks Meter: 3 | Anylink N99i looking dead Client says that it's died "itself". So, trying to find the way to SW repair, connected in 3 hands with eagle to pinouts on PCB. Cannot solder, because client doesn't want that. So, it's possible to keep only for period of backup EEPROM... Connecting, finding MT6226, and exact before saving window appear =- got the message about possible damaged flash chip and propositioon to use NAND read. But NAND is the same result. Before he gave phone to me, it was several times reboot of the phone. Does anybody has normal pinout for 1x12 mini connector cable? Could you give exact step-by-step instructions on how to repair SW problem in this 2 CPU model? Also (if not need to reball chips) - how to repair reboot of the phone? Would be really thanksful for help. BR! |
04-09-2008, 23:42 | #2 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! check with multimeter resistance between Tx/rx test points and system connector pins. please note that in some cases resistance can be not 0 ohm, but some small value. this way you can make good cable. regarding your problem- you must start from FFS formating on MCU1 |
04-10-2008, 12:30 | #4 (permalink) | |
Member: 196693 Status: Offline Thanks Meter: 3 | Quote:
Also, as I am new with multimeter using, what exact doings should I do? All testpoints on PCB, shown in Infinity box pinouts, are working, but client dos not allow to solder a wire to them. Impossible to keep so long time wire in hands...during backup/flash. So, that's why I need cable pinouts. | |
04-10-2008, 14:47 | #5 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! set multimeter to resistance mesuring mode. now when you connect both probes together- you will see resistance 0 (zero) and hear Beep. now how to find GND: connect one probe to some grounded phone part (for example metal shield which covers PCB or negative terminal of battery connector) and with other prob touch one by one system connector pins. as soon as you hear Beep- check multimeter LCD and if there will be small resistance between 0-2...3 Ohm- this is a needed pin. Same way you test test points. Set one probe to test point, with other touch all pins on system connector. If you hear Beep and see some small resistnace- this means it has connection with this test points. and you can use this pin for cable connecting |
04-10-2008, 20:40 | #6 (permalink) |
Member: 196693 Status: Offline Thanks Meter: 3 | Thanks a lot for answering. Found GND on system connector, but not working RX/TX. Phone now doesn't power on. So, I took GND with cable connector and RX/TX on PCB as shown in box pinouts photos. Have such a result: COM4 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: read eeprom Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6226:8A02:8A01]... CPU: MT6226 high speed boot disabled chip: 0031:40B5:4D85 high speed disabled boot step size: 0002 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... error: wrong answer: 3B error: wrong answer: 3B : wrong answer after chip id request error: wrong answer: 3B error: wrong answer: 3B : wrong answer after chip cfi request error: wrong answer: 3B : wrong answer after chip id request number of flash chip/regions detected: 00/01 Unknown or damaged flash chip, operation aborted. Fault reasons: 1. damaged flash chip: replace or resolder/reball flash chip 2. damaged hardware: check hardware, water inside etc. 3. unknown hardware: set "Advanced chip detection method" box [un-checked] and try again 4. wrong model selection, try 'NAND' selection Initialize Fail Finished, time used: 165 sec Remove/Install battery now ! Very bad? Or possible that it's only SW problems? |
04-10-2008, 21:42 | #7 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! by this log i can say that it looks like flash IC is dead or have bad soldering. i would advice to open phone and and re-solder flash IC or at least to heat it. here is similar problem and it's solution: http:///vbb/showth...=464301&page=4 |
04-13-2008, 21:54 | #8 (permalink) |
Member: 196693 Status: Offline Thanks Meter: 3 | Thanks a lot. Found GND is 10th PIN on system connector. RX/TX not appear...maybe because of dead phone? Tomorrow will look on PCB and heat flash if needed. After that we'll see. Also, possible will try to make backup of both CPU FF. |
04-13-2008, 22:01 | #9 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | @vital belarus btw, this may helps: http://www.mcrf.ru/forum/forumdisplay.php?f=221 |
04-17-2008, 11:04 | #10 (permalink) | |
Freak Poster Join Date: Nov 2005
Member: 202820 Status: Offline Thanks Meter: 11 | Quote:
i serche pinout for my anylink n-99i i wainting | |
04-17-2008, 11:25 | #11 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! please post your anylink n99i connector type. also please dont forget that it is very useful "search" button on this forum. might be someone already requested/posted this pinout |
04-30-2008, 20:58 | #13 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! are you sure it is MT62xx MCU based? Cant find any pinout for connector 2x7. open phone, check MCU and also look for Test points. if you fail to find test points i can advice how to find pinout using multimeter |
pin out for anylink n99i | spring2005 | Chinese Cocktail | 5 | 04-18-2008 11:35 |
Anylink N99i Games? | lewbie | Chinese Models & Cloned Phones | 2 | 04-15-2008 12:57 |
ANYLINk N99i | developper | Various | 0 | 02-03-2008 21:09 |
ANYLINk N99i codes | developper | Various | 2 | 02-03-2008 20:36 |
ANYLINK N99i DEAD | rkinfo_imran | Infinity-Box | 1 | 11-25-2007 09:33 |
