03-28-2018, 19:21 | #1 (permalink) |
Freak Poster Join Date: Jan 2017
Member: 2671513 Status: Offline Thanks Meter: 121 | asus x800d help please Infinity-Box Android Service Tool [AST] v1.03 Operation : Identify (ADB) [ v1.03 ] Waiting for device in ADB mode ... 1. Connect device, enable 'DEVELOPER MODE' and 'USB DEBUG', if need! 2. Insert USB cable, accept AUTH on PhoneScreen, if software ask! Connect Ok! Device Info : Vendor : asus Model : ASUS_X008D Device : WW_Phone Android : 6.0 Product : ASUS_X008D Brand : asus Serial : 111111111111111 Build_tm : Thu Mar 16 14:15:34 CST 2017 DisplayID : MRA58K.WW_Phone-13.1.0.91-20170306 Patch Ver : MRA58K SecPatch : 2017-01-05 Hardware : mt6735 MTK SVer : WK3ME1B4-2 MTK HVer : MT6737M MTK Prj : alps-mp-m0.mp1-V2.84_gr6737m.65.m0_P111 HW Board : MT6737 CPU rel : arm64-v8a SIM Card : NOT_READY,NOT_READY USB Conf : mtp,adb Sys USB : mtp,adb FS Crypt : encrypted Done! Elapsed: 00:00:23 ****************************************** info by ast fastboot : Operation : Identify [ v1.03 ] Waiting for device in fastboot mode ... 1. Power off device. Press and hold 'VOL DOWN' button 2. Insert USB cable, hold button until device will be found! Connect Ok! INFO : max-download-size: 0x8000000 INFO : partition-size:flashinfo: 1000000 INFO : partition-type:flashinfo: raw data INFO : partition-size:userdata: 32000000 INFO : partition-type:userdata: ext4 INFO : partition-size:cache: 19000000 INFO : partition-type:cache: ext4 INFO : partition-size:system: f4000000 INFO : partition-type:system: ext4 INFO : partition-size:metadata: 2300000 INFO : partition-type:metadata: raw data INFO : partition-size:nvdata: 2000000 INFO : partition-type:nvdata: ext4 INFO : partition-size:frp: 100000 INFO : partition-type:frp: raw data INFO : partition-size:ADF: 2800000 INFO : partition-type:ADF: raw data INFO : partition-size:APD: a000000 INFO : partition-type:APD: raw data INFO : partition-size:factory: a00000 INFO : partition-type:factory: raw data INFO : partition-size:tee2: 500000 INFO : partition-type:tee2: raw data INFO : partition-size:tee1: 500000 INFO : partition-type:tee1: raw data INFO : partition-size:keystore: 800000 INFO : partition-type:keystore: raw data INFO : partition-size:secro: 600000 INFO : partition-type:secro: raw data INFO : partition-sizeemkeystore: 200000 INFO : partition-typeemkeystore: raw data INFO : partition-size:seccfg: 80000 INFO : partition-type:seccfg: raw data INFO : partition-size:expdb: a00000 INFO : partition-type:expdb: raw data INFO : partition-size:logo: 800000 INFO : partition-type:logo: raw data INFO : partition-size:recovery: 1000000 INFO : partition-type:recovery: raw data INFO : partition-size:boot: 1000000 INFO : partition-type:boot: raw data INFO : partition-sizeara: 80000 INFO : partition-typeara: raw data INFO : partition-size:lk: 80000 INFO : partition-type:lk: raw data INFO : partition-sizerotect2: a00000 INFO : partition-typerotect2: ext4 INFO : partition-sizerotect1: a00000 INFO : partition-typerotect1: ext4 INFO : partition-size:nvram: 500000 INFO : partition-type:nvram: raw data INFO : partition-sizeroinfo: 300000 INFO : partition-typeroinfo: raw data INFO : partition-sizereloader: 40000 INFO : partition-typereloader: raw data INFO : off-mode-charge: 1 INFO : warranty: yes INFO : unlocked: no INFO : secure: yes INFO : kernel: lk INFO : product: D281L INFO : version-preloader: 0.1.00 INFO : version: 0.5 INFO : Done!! OEM : FAILunknown command Done! Elapsed: 00:00:06 ******************************** info cm2 mtk : Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 7 ] Sync... Inital Boot Ok! BB_CPU_PID : 6737 BB_CPU_NME : [MediaTek] MT6737M|MT6737_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x01000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : SIGNED with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... [DA_ERROR] : SECURITYBOOT_BOOT_NOT_ACCEPTED Boot Error! Operation Failed Elapsed: 00:00:04 Reconnect Power/Cable! ************************************** |
03-28-2018, 20:14 | #2 (permalink) |
Member: 2671513 Status: Offline Thanks Meter: 121 | Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 7 ] Sync... Inital Boot Ok! BB_CPU_PID : 6737 BB_CPU_NME : [MediaTek] MT6737M|MT6737_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x01000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : SIGNED with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v3.3001.00.00 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 484A019061344742160EA4322D492495 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , 2a4GB [eMMC] : FLASH_CID : 90014A484247346132A40E169524B32D [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x0000000747C00000 [eMMC] : FLASH_UCP : 29820 MiB [eMMC 32 GiB] DEV RID : 0x0D434F4D70830B7BC55D2C513BE20F0E INT RAM : 0x00020000 EXT RAM : 0xC0000000 [3 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : asus ProdName : WW_Phone ProdModel : ASUS_X008D Device : ASUS_X008_1 AndroidVer: 6.0 MTKxCPU : MT6737M MTKxPRJ : alps-mp-m0.mp1-V2.84_gr6737m.65.m0_P111 EXTRA : LCD : Not info available LCD Res : M_HEIGHT=1280xM_WIDTH=720 TOUCH [0] : STOM_KERNEL_TOUCHPANEL= TOUCH [1] : GT1XX CAM [0] : STOM_HAL_IMGSENSOR=imx258_mipi_raw CAM [1] : s5k3l8_mipi_raw CAM [2] : s5k3l8_mipi_raw_new CAM [3] : s5k3m2_mipi_raw CAM [4] : hi551_mipi_raw CAM [5] : ov13853_mipi_raw CAM [6] : ov5670_mipi_raw CAM [7] : hi553_mipi_raw CAM [8] : s5k5e8yx_mipi_raw MODEM : STOM_MODEM=E281LWW_LWG_DSDS_COTSX_CBON_RFPA_77910 LOCALE : K_PRODUCT_LOCALES= en_US zh_CN zh_TW es_ES pt_BR ru_RU fr_FR de_DE tr_TR vi_VN ms_MY in_ID th_TH it_IT ar_EG hi_IN bn_IN ur_PK fa_IR pt_PT nl_NL el_GR hu_HU tl_PH ro_RO cs_CZ ko_KR km_KH iw_IL my_MM pl_PL es_US bg_BG hr_HR lv_LV lt_LT sk_SK uk_UA de_AT da_DK fi_FI nb_NO sv_SE en_GB hy_AM zh_HK et_EE ja_JP kk_KZ sr_RS sl_SI ca_ES Done! Elapsed: 00:00:09 Reconnect Power/Cable! ******************************************* to be continued ....................... |
03-28-2018, 20:17 | #3 (permalink) |
Member: 2671513 Status: Offline Thanks Meter: 121 | Operation : Read Flash [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 7 ] Sync... Inital Boot Ok! BB_CPU_PID : 6737 BB_CPU_NME : [MediaTek] MT6737M|MT6737_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x01000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : SIGNED with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v3.3001.00.00 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 484A019061344742160EA4322D492495 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , 2a4GB [eMMC] : FLASH_CID : 90014A484247346132A40E169524B32D [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x0000000747C00000 [eMMC] : FLASH_UCP : 29820 MiB [eMMC 32 GiB] DEV RID : 0x0D434F4D70830B7BC55D2C513BE20F0E INT RAM : 0x00020000 EXT RAM : 0xC0000000 [3 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Content now ... xGPT : Normalize settings Ok! Brand : asus ProdName : WW_Phone ProdModel : ASUS_X008D Device : ASUS_X008_1 AndroidVer: 6.0 MTKxCPU : MT6737M MTKxPRJ : alps-mp-m0.mp1-V2.84_gr6737m.65.m0_P111 [Read Ok] : preloader_d281l.bin [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : logo.bin [Read Ok] : secro.img [Read Ok] : tz1.img [Read Ok] : tz2.img [Read Ok] : factory.img [Read Ok] : apd.img [Read Ok] : adf.img [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : userdata.img [ScatCFG] : MT6737M / V1.1.2 / d281l / EMMC Android Info saved HWConfig Info saved FW Size : 2638 MiB Scatter saved to : F:\cm2 dump\asus x008d\MT6737M__asus__ASUS_X008D__ASUS_X008_1__6.0_ _alps-mp-m0.mp1-V2.84_gr6737m.65.m0_P111\ All done! Done! Elapsed: 00:11:40 Reconnect Power/Cable! ************************************************** ********* to be continued....................... |
03-28-2018, 22:00 | #4 (permalink) |
Member: 2671513 Status: Offline Thanks Meter: 121 | need nvram please asus x008d Chinese Miracle II [MTK module] v 1.58 Operation : Fix Unknown BaseBand [ v1.58 ] User accepted FixBB operation! 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 7 ] Sync... Inital Boot Ok! BB_CPU_PID : 6737 BB_CPU_NME : [MediaTek] MT6737M|MT6737_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x01000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : SIGNED with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v3.3001.00.00 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 484A019061344742160EA4322D492495 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , 2a4GB [eMMC] : FLASH_CID : 90014A484247346132A40E169524B32D [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x0000000747C00000 [eMMC] : FLASH_UCP : 29820 MiB [eMMC 32 GiB] DEV RID : 0x0D434F4D70830B7BC55D2C513BE20F0E INT RAM : 0x00020000 EXT RAM : 0xC0000000 [3 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Step #1 Step #1 ... Ok Step #2 Step #2 ... Ok Step #3 Step #3 ... Ok Reset Done! Done! Elapsed: 00:00:21 Reconnect Power/Cable! **************************************** to repair imei because unknown base band please help |
03-29-2018, 03:11 | #5 (permalink) |
Freak Poster Join Date: Jul 2017
Member: 2739340 Status: Offline Thanks Meter: 74 | Asus is a useless phone bye they way if you want to repair your baseband need to update because of downgrade it’s become like this |
The Following User Says Thank You to Oppo_Tool For This Useful Post: |
03-29-2018, 03:15 | #6 (permalink) | |
Member: 2671513 Status: Offline Thanks Meter: 121 | Quote:
can i use this to update ? or other firmware? i have ww_phone 13 version and this update is ww_phone 14 ? i have full backup of the phone ( for emergency ) | |
03-29-2018, 07:18 | #8 (permalink) |
Member: 2671513 Status: Offline Thanks Meter: 121 | i think phone is flashed with spft (format + download ) before, because in wifi ( nvram error ) and i tryed officiel update but not compatible with MRA58K the firmware in phone ( MRA58K.WW_Phone-13.1.0.91-20170306 ) then only nvram can solve the problem ( unknow base bande + imei null ) |
