11-28-2016, 07:03 | #1 (permalink) |
No Life Poster Join Date: Feb 2006 Location: Anywhere
Member: 233142 Status: Offline Sonork: 100.1595099 Thanks Meter: 528 | Starextrem 5 reset frp faild and wont start now Please need help STAREXTREM 5 locked FRP after tried to reset it now it wont start Code: Card found : S/N : 334FA6A3 , v0134 Chinese Miracle II [MTK module] v 1.58 Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 63 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 484A019065324741CA1F0705EB0001E0 Initialize Memory ... DRAM configured from IDB! DRAM initialize passed! DRAM size : 0x40000000 [DA_ERROR] : DA Load failed! ErroCode : 0x2008 DA_LOAD_FAILED Boot Error! Operation Failed Elapsed: 00:00:20 Reconnect Power/Cable! |
11-28-2016, 07:15 | #2 (permalink) | ||
No Life Poster Join Date: Dec 2004 Location: Uganda Age: 45
Member: 96478 Status: Offline Sonork: 100.1674604 Thanks Meter: 1,421 | Quote:
Now Write backup phone will come to Normal then do other Operations as well. | ||
