12-22-2017, 01:22 | #1 (permalink) |
No Life Poster Join Date: Oct 2004 Location: Madeira Island Age: 47
Member: 85718 Status: Offline Thanks Meter: 451 | XT1622 FRP no network Check log Operation : Identify [ v1.03 ] Waiting for device in fastboot mode ... 1. Power off device. Press and hold 'VOL DOWN' button 2. Insert USB cable, hold button until device will be found! Device not found! Check cable, drivers and conection! Operation : Identify [ v1.03 ] Waiting for device in fastboot mode ... 1. Power off device. Press and hold 'VOL DOWN' button 2. Insert USB cable, hold button until device will be found! Device not found! Check cable, drivers and conection! Operation : Identify [ v1.03 ] Waiting for device in fastboot mode ... 1. Power off device. Press and hold 'VOL DOWN' button 2. Insert USB cable, hold button until device will be found! Connect Ok! Main Info ============ CPU : MSM8952 CID : 0x0032 IMEI : 354123074105372 UID : A7BF140200000000000000000000 Model Info ============ DevModel : XT1622 IntName : athene_13mp SW Info ============ DevSWVer : Blur_Version.25.211.8.athene.retail.en.US DevQCVer : LA.BR.1.3.6-01710-8976.0 BaseBand : M8952_70004.04.03.32R ATHENE_EMEA_DSDS_CUST BootLDRv : moto-msm8952-B1.06 HW Info ============ eMMCInfo : 16GB SKHYNIX HAG4a2 RV=08 PV=E4 FV=00000000000000E4 DRAMInfo : 2GB SKHYNIX LP3 DIE=8Gb M5=06 M6=03 M7=00 M8=1F Lock Info ============ WarrantyVoid : no FRP Lock : protected (144) Done! Elapsed: 00:00:11 Operation : Reset FRP (ADB) [ v1.03 ] Waiting for device in ADB mode ... 1. Connect device, enable 'DEVELOPER MODE' and 'USB DEBUG', if need! 2. Insert USB cable, accept AUTH on PhoneScreen, if software ask! Device not found! Check cable, drivers and conection! Operation : Moto ADB Enable [ v1.03 ] Mode : Enable ADB Waiting for NetInterface arrival ... 1. Power off device. Press and hold 'VOL DOWN' and 'POWER ON' buttons 2. Select by 'VOL DOWN' or 'VOL UP' FACTORY MODE , press 'POWER ON' 3. Connect USB cable, when device boot complete! Connect Ok! Waiting ... Trying link with : 192.168.137.2 Connected to device! Device : XT1622 Switching to FACTORY ... Setting Unsecure mode Waiting device ... Connect Ok! Trying link with : 192.168.137.2 Connected to device! Device : XT1622 Setting ADB ... Waiting device ... Connect Ok! Trying link with : 192.168.137.2 Connected to device! Device : XT1622 Setting ADB ... 1. Disconnect cable from device, wait device reboot 2. Make "Reset FRP" 3. Disable "FACTORY MODE" after operations done! Done! Elapsed: 00:03:56 Last edited by ct3im; 12-22-2017 at 01:30. |
12-22-2017, 16:42 | #6 (permalink) |
Member: 85718 Status: Offline Thanks Meter: 451 | In fact not completely done, probably I am doing something wrong , please I need the correct way to FACTORY MODE out , i choice the option START and phone restart and network appears , but if I power off and power on again the phone no network , to have network again is necessary repeat the process (vol- and power next choice START) |
