08-28-2019, 14:59 | #1 (permalink) |
Freak Poster Join Date: Dec 2013
Member: 2095478 Status: Offline Thanks Meter: 49 | Avvio G201 Wrong SIM ==== [28-Aug-19 12:00:27 PM] ==== COM831 [VCP0] selected module v4.48 Device: Avvio-G200 Checking data, wait... advanced flash detection enabled Action: "sp-unlock" Warning ! After unlock process finished make this: 1. be sure that there is NO any SIM card in phone 2. press phone "Power" button and power-On phone 3. press phone "Power" button and power-Off phone 4. NOTE ! SIM card can be blocked during first power-On so use SIM card that you ready to move to trash w/o problems ! 5. now you can power-On phone with SIM card Do you understand instruction and want to continue ? unlock method: standard fast Unlock procedure can be faster if you skip ffs/eeprom area backup procedure. Do you want to disable ffs/eeprom backup ? ffs/eeprom backup disabled ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6205:8B00]... CPU: MT6205 high speed boot On boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC22A000000000:18E59F00000000 flash: Samsung AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb otp offset: 003F0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... interesting cpu type found Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... ..usb bootloader detect (phase #2)... ..usb bootloader (chip) is absent searching rom info... .search rom info finished searching rom info... .search rom info finished warning: rom info information not found, possible reasons: - old firmware type w/o rom info information - empty (completely or partially erased) flash chip - damaged firmware - damaged hardware (bad soldered or damaged flash chip) > if phone works fine just ignore this warning < ffs/eeprom address can not be detected, value from database assigned: 00300000/00100000 sec info (detailed) detection... searching sec info#1... .search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... flash: EC22A000000000:18E59F00000000 Backup required data Done ====> Patch required data ... .......lock area found Patch required data Done ====> Special operation ... detecting parameters to apply patch area 1... ................error: area 1 can not apply patch Special operation Done ====> Write ... flash: EC22A000000000:18E59F00000000 flash: EC22A000000000:18E59F00000000 Write: lock-area-1 Write Done ====> Finalization ... Finalization Done Finished, time used: 36 sec Remove/Install battery now ! COM831 ready ==== [28-Aug-19 12:17:51 PM] ==== COM831 [VCP0] selected module v4.48 Device: Avvio-G200 Checking data, wait... advanced flash detection enabled Action: "sp-unlock" Warning ! After unlock process finished make this: 1. be sure that there is NO any SIM card in phone 2. press phone "Power" button and power-On phone 3. press phone "Power" button and power-Off phone 4. NOTE ! SIM card can be blocked during first power-On so use SIM card that you ready to move to trash w/o problems ! 5. now you can power-On phone with SIM card Do you understand instruction and want to continue ? unlock method: standard ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6205:8B00]... CPU: MT6205 high speed boot On boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC22A000000000:18E59F00000000 flash: Samsung AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb otp offset: 003F0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... interesting cpu type found Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... ..usb bootloader detect (phase #2)... ..usb bootloader (chip) is absent searching rom info... .search rom info finished searching rom info... .search rom info finished warning: rom info information not found, possible reasons: - old firmware type w/o rom info information - empty (completely or partially erased) flash chip - damaged firmware - damaged hardware (bad soldered or damaged flash chip) > if phone works fine just ignore this warning < ffs/eeprom address can not be detected, value from database assigned: 00300000/00100000 sec info (detailed) detection... searching sec info#1... .search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: Avvio-G200__ffs... file saved: C:\InfinityBox\MModule\Avvio-G200__ffs_20190828-121956.B0E.bin flash: EC22A000000000:18E59F00000000 Backup required data Done ====> Patch required data ... detection procedure, wait... detection procedure completed Patch required data Done ====> Special operation ... detecting parameters to apply patch area 1... ................error: area 1 can not apply patch Special operation Done ====> Write ... flash: EC22A000000000:18E59F00000000 Write: ffs Write Done ====> Finalization ... Finalization Done Finished, time used: 2 min 40 sec Remove/Install battery now ! |
