b259 samsung cdma sucessfully unlocked COM5 [VCP0] selected module v1.03 Device: Samsung-SCH-B259 Checking data, wait... Action: unlock Phone should be Switched ON ! Connecting, wait... Phone detected, wait... step-1 done step-2 done step-3 done operation finished Finished, time used: 13 sec Remove/Install battery now ! thxs.infinity team...................................... wbr. rajesh ch. |
Each test report with attached logs is very important for us so we can see how is Infinity-Box software works, what is phone hardware configuration (f.e. flash chip type) and what is possible problems (so we will be able to fix it) and successfully done work. |
b259 samsung cdma pls solution this problem COM63 [sscdmdm0] selected module v2.05 Device: Samsung-SCH-B239, B259, B279, F302 operation: SP-unlock Phone should be Switched ON ! connecting... Connecting, wait... error: can't activate test mode If phone can not be connected after several tries make this: 1. Insert original sim card in phone 2. Power-On phone 3. go to Menu, press 6 then * and type password 123456 4. go to "Port Map", HKF 5. select "UART1" If problem still exist make this: 1. Insert original sim card in phone 2. Power-On phone 3. go to Menu, press 47*869#123580 4. go to "Port Map", HKF 5. select "UART2" error: operation failed Finished, time used: 25 sec |
post in infinity CDMA section. |
Open Back Sticker You Will Be See Some Pinout Just Make Jumper And Unlock By Normal Any Rx Tx Cable Here Is Cable Pinout http://s23.postimg.org/cbyvuea5n/download_1.jpg |
Thank you pradip kus Rj-45 cable kat kar Rx-Tx Vcc Gnd Connect kiya 10 Second me hogaya. COM41 [VCP0] selected Samsung B259 succsess unlock- Green mobile raver 9881365569 module v2.05 Device: Samsung-SCH-B239, B259, B279, F302 operation: SP-unlock Phone should be Switched ON ! connecting... Connecting, wait... Phone detected, wait... step-1 done step-2 done step-3 done operation finished Finished, time used: 37 sec |
plese infinity support Sir... Samsung B539 ki flash file chahiye urjent.blinking problem hai. Not available in infinity support. thankyou infinity support |
