04-10-2021, 09:50 | #1 (permalink) |
No Life Poster Join Date: Feb 2011 Location: (BaNgLaDeSh).(U.A.E,AD)
Member: 1511441 Status: Offline Sonork: 100.1604057 Thanks Meter: 1,162 | oppo cph1989 password reset done but phone still have password Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.21 Load IDBase v21168 Ok! Operation : Reset Settings/Format FS [ v2.21 ] Mode : META 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1632 (COM4) MODE : BOOTROM PORT : 4 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6771 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : MODERN RAPHAEL BROM : MEID : 11FEBED26113CDEBAAF4C644A427212F BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BOOTROM BROM : LOG : F0: 102B 0000 F3: 1001 0000 [0200] F3: 1001 0000 F7: 0000 0000 V0: 0000 0000 [0001] BROM : SOCID : E04A3018D8790E7E602CD9AD7581C16D6CEAF19BD4110AEF7F 1E7E58F3BFBA39 BROM : Configuring target for META BROM : META configured! INIT : META confirmed! Boot done! AP_CHIP : MT6771 AP_SWTM : Sat Mar 21 03:19:53 CST 2020 AP_SWVR : CPH1989_11_A.15_200321_e82cc6bd Format Ok : UserData - > Format in META will NOT reset FRP! Done! Elapsed: 00:00:52 Reconnect Power/Cable! https://*********/FSWKJmrhVZs |
The Following User Says Thank You to riajul1988 For This Useful Post: |
04-10-2021, 11:39 | #4 (permalink) | |
Member: 314003 Status: Offline Thanks Meter: 2,999 | Quote:
MT2 Meta Format Not Support Oppo Up Down Ssla Tick Format Check | |
04-10-2021, 14:04 | #7 (permalink) | |
Member: 1511441 Status: Offline Sonork: 100.1604057 Thanks Meter: 1,162 | Quote:
Card found : 5888D48A , v0147 Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.21 Load IDBase v21168 Ok! Operation : Reset Settings/Format FS [ v2.21 ] Mode : SMART RESET 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1632 (COM4) MODE : BOOTROM PORT : 4 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6771 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Sylvia TYPE : MODERN RAPHAEL BROM : MEID : 11FEBED26113CDEBAAF4C644A427212F BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : Oppo : F11-Reno2F | Manual : Enabled BROM : SOCID : E04A3018D8790E7E602CD9AD7581C16D6CEAF19BD4110AEF7F 1E7E58F3BFBA39 AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6771 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : 0x00007017 : DA SEND ERROR! ERROR : SECURE BOOT : SLA REQUIRED IN BROM MODE! INFO : BROM Level : CERT/AUTH required! Try boot device in PRELOADER mode with select PL/PL_CRYPTO/SWSEC type! Error : Fail to init protocol! >>> Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! operation : Reset Settings/Format FS [ v2.21 ] Mode : FACTORY RESET ( WIPE ) 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1632 (COM4) MODE : BOOTROM PORT : 4 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6771 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Sylvia TYPE : MODERN RAPHAEL BROM : MEID : 11FEBED26113CDEBAAF4C644A427212F BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : Oppo : F11-Reno2F | Manual : Enabled BROM : SOCID : E04A3018D8790E7E602CD9AD7581C16D6CEAF19BD4110AEF7F 1E7E58F3BFBA39 BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6771 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : MT6752 EMI : SRC : preloader_oppo6771.bin EMI : CNT : 001A EMI : [00] : eMMC : LP_DDR4X : ID : 150100445636444D42 : VEN : SAMSUNG | DEV : DV6DMB : RAM : [ 4.00 GB ] EMI : [01] : eUFS : LP_DDR4X : DEV : KM5V8001DM-B622 : RAM : [ 4.00 GB ] EMI : [02] : eMMC : LP_DDR4X : ID : 150100335636434D42 : VEN : SAMSUNG | DEV : 3V6CMB : RAM : [ 6.00 GB ] EMI : [03] : eUFS : LP_DDR4X : DEV : KM5V7001DM-B621 : RAM : [ 4.00 GB ] EMI : [04] : eMMC : LP_DDR4X : ID : 150100334836434142 : VEN : SAMSUNG | DEV : 3H6CAB : RAM : [ 6.00 GB ] EMI : [05] : eMMC : LP_DDR4X : ID : 90014A68433861503E : VEN : HYNIX | DEV : hC8aP> : RAM : [ 6.00 GB ] EMI : [06] : eMMC : LP_DDR4X : ID : 13014E53304A394B39 : VEN : MICRON | DEV : S0J9K9 : RAM : [ 4.00 GB ] EMI : [07] : eMMC : LP_DDR4X : ID : 150100444836444142 : VEN : SAMSUNG | DEV : DH6DAB : RAM : [ 4.00 GB ] EMI : [08] : eMMC : LP_DDR4X : ID : 90014A68433861503E : VEN : HYNIX | DEV : hC8aP> : RAM : [ 4.00 GB ] EMI : [09] : eUFS : LP_DDR4X : DEV : MT128GASAO4U21 : RAM : [ 6.00 GB ] EMI : [0A] : eUFS : LP_DDR4X : DEV : MT128GASAO4U21 : RAM : [ 8.00 GB ] EMI : [0B] : eMMC : LP_DDR4X : ID : 13014E53304A394B38 : VEN : MICRON | DEV : S0J9K8 : RAM : [ 4.00 GB ] EMI : [0C] : eMMC : LP_DDR4X : ID : 13014E53304A394D39 : VEN : MICRON | DEV : S0J9M9 : RAM : [ 6.00 GB ] EMI : [0D] : eMMC : LP_DDR4X : ID : 13014E53304A394438 : VEN : MICRON | DEV : S0J9D8 : RAM : [ 4.00 GB ] EMI : [0E] : eUFS : LP_DDR4X : DEV : KM2B8001CM-BB01 : RAM : [ 6.00 GB ] EMI : [0F] : eMMC : LP_DDR4X : ID : 450100444134313238 : VEN : SANDISK | DEV : DA4128 : RAM : [ 4.00 GB ] EMI : [10] : eUFS : LP_DDR4X : DEV : KM8V7001JM-B810 : RAM : [ 8.00 GB ] EMI : [11] : eUFS : LP_DDR4X : DEV : KM2V8001CM-B707 : RAM : [ 6.00 GB ] EMI : [12] : eUFS : LP_DDR4X : DEV : KM8B8001JM-BC01 : RAM : [ 8.00 GB ] EMI : [13] : eUFS : LP_DDR4X : DEV : H9HQ22AECMMDAR : RAM : [ 6.00 GB ] EMI : [14] : eUFS : LP_DDR4X : DEV : KM8V8001JM-B813 : RAM : [ 8.00 GB ] EMI : [15] : eUFS : LP_DDR4X : DEV : MT128GASAO4U21 : RAM : [ 4.00 GB ] EMI : [16] : eUFS : LP_DDR4X : DEV : H28S8Q302CMR : RAM : [ 6.00 GB ] EMI : [17] : eUFS : LP_DDR4X : DEV : H9HQ16AFAMMDAR : RAM : [ 8.00 GB ] EMI : [18] : eUFS : LP_DDR4X : DEV : H9HQ22AFAMMDAR : RAM : [ 8.00 GB ] EMI : [19] : DRAM : LP_DDR4X : ID : NOT_DEFINED : VEN : UNKNOWN | DEV : : RAM : [ 6.00 GB ] EMI : Init EMI from PRELOADER EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00039000 [ 228.00 KB ] DRAM: 0x200000000 [ 8.00 GB ] UFS: CE014B4D3856373030314A4D2D423831 UFS: VEN : 0x01CE VID : KM8V7001JM-B81 IFW : 0900 LU0 : 0x00400000 [ 4.00 MB ] LU1 : 0x00400000 [ 4.00 MB ] LU2 : 0x1DCB000000 [ 119.17 GB ] FSN : 00330039006500620039003100330033 REG : 0x101010000 CHIP : MT6771 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : C9A6E5282542D3EB9A2529F892BDD2FA DA : USB : HIGH-SPEED Boot done! ERR : 0xC002002A ERR : SEC : IMG TYPE MISMATCH ERR : 0x00001000|0x00001000 Error : Failed erase block! >>> Try select another format mode! Reconnect Power/Cable! Last edited by riajul1988; 04-10-2021 at 14:09. | |
04-11-2021, 14:44 | #14 (permalink) |
Member: 1511441 Status: Offline Sonork: 100.1604057 Thanks Meter: 1,162 | done redinfo with ssla tick Card found : 5888D*** , v0147 Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.21 Load IDBase v21168 Ok! Operation : Identify [ v2.21 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1632 (COM4) MODE : BOOTROM PORT : 4 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6771 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Sylvia TYPE : MODERN RAPHAEL BROM : MEID : 11FEBED26113CDEBAAF4C644A427212F BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : Oppo : F11-Reno2F | Manual : Disabled BROM : SOCID : E04A3018D8790E7E602CD9AD7581C16D6CEAF19BD4110AEF7F 1E7E58F3BFBA39 BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6771 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : MT6752 EMI : SRC : preloader_oppo6771.bin EMI : CNT : 001A EMI : [00] : eMMC : LP_DDR4X : ID : 150100445636444D42 : VEN : SAMSUNG | DEV : DV6DMB : RAM : [ 4.00 GB ] EMI : [01] : eUFS : LP_DDR4X : DEV : KM5V8001DM-B622 : RAM : [ 4.00 GB ] EMI : [02] : eMMC : LP_DDR4X : ID : 150100335636434D42 : VEN : SAMSUNG | DEV : 3V6CMB : RAM : [ 6.00 GB ] EMI : [03] : eUFS : LP_DDR4X : DEV : KM5V7001DM-B621 : RAM : [ 4.00 GB ] EMI : [04] : eMMC : LP_DDR4X : ID : 150100334836434142 : VEN : SAMSUNG | DEV : 3H6CAB : RAM : [ 6.00 GB ] EMI : [05] : eMMC : LP_DDR4X : ID : 90014A68433861503E : VEN : HYNIX | DEV : hC8aP> : RAM : [ 6.00 GB ] EMI : [06] : eMMC : LP_DDR4X : ID : 13014E53304A394B39 : VEN : MICRON | DEV : S0J9K9 : RAM : [ 4.00 GB ] EMI : [07] : eMMC : LP_DDR4X : ID : 150100444836444142 : VEN : SAMSUNG | DEV : DH6DAB : RAM : [ 4.00 GB ] EMI : [08] : eMMC : LP_DDR4X : ID : 90014A68433861503E : VEN : HYNIX | DEV : hC8aP> : RAM : [ 4.00 GB ] EMI : [09] : eUFS : LP_DDR4X : DEV : MT128GASAO4U21 : RAM : [ 6.00 GB ] EMI : [0A] : eUFS : LP_DDR4X : DEV : MT128GASAO4U21 : RAM : [ 8.00 GB ] EMI : [0B] : eMMC : LP_DDR4X : ID : 13014E53304A394B38 : VEN : MICRON | DEV : S0J9K8 : RAM : [ 4.00 GB ] EMI : [0C] : eMMC : LP_DDR4X : ID : 13014E53304A394D39 : VEN : MICRON | DEV : S0J9M9 : RAM : [ 6.00 GB ] EMI : [0D] : eMMC : LP_DDR4X : ID : 13014E53304A394438 : VEN : MICRON | DEV : S0J9D8 : RAM : [ 4.00 GB ] EMI : [0E] : eUFS : LP_DDR4X : DEV : KM2B8001CM-BB01 : RAM : [ 6.00 GB ] EMI : [0F] : eMMC : LP_DDR4X : ID : 450100444134313238 : VEN : SANDISK | DEV : DA4128 : RAM : [ 4.00 GB ] EMI : [10] : eUFS : LP_DDR4X : DEV : KM8V7001JM-B810 : RAM : [ 8.00 GB ] EMI : [11] : eUFS : LP_DDR4X : DEV : KM2V8001CM-B707 : RAM : [ 6.00 GB ] EMI : [12] : eUFS : LP_DDR4X : DEV : KM8B8001JM-BC01 : RAM : [ 8.00 GB ] EMI : [13] : eUFS : LP_DDR4X : DEV : H9HQ22AECMMDAR : RAM : [ 6.00 GB ] EMI : [14] : eUFS : LP_DDR4X : DEV : KM8V8001JM-B813 : RAM : [ 8.00 GB ] EMI : [15] : eUFS : LP_DDR4X : DEV : MT128GASAO4U21 : RAM : [ 4.00 GB ] EMI : [16] : eUFS : LP_DDR4X : DEV : H28S8Q302CMR : RAM : [ 6.00 GB ] EMI : [17] : eUFS : LP_DDR4X : DEV : H9HQ16AFAMMDAR : RAM : [ 8.00 GB ] EMI : [18] : eUFS : LP_DDR4X : DEV : H9HQ22AFAMMDAR : RAM : [ 8.00 GB ] EMI : [19] : DRAM : LP_DDR4X : ID : NOT_DEFINED : VEN : UNKNOWN | DEV : : RAM : [ 6.00 GB ] EMI : Init EMI from PRELOADER EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00039000 [ 228.00 KB ] DRAM: 0x200000000 [ 8.00 GB ] UFS: CE014B4D3856373030314A4D2D423831 UFS: VEN : 0x01CE VID : KM8V7001JM-B81 IFW : 0900 LU0 : 0x00400000 [ 4.00 MB ] LU1 : 0x00400000 [ 4.00 MB ] LU2 : 0x1DCB000000 [ 119.17 GB ] FSN : 00330039006500620039003100330033 REG : 0x101010000 CHIP : MT6771 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : C9A6E5282542D3EB9A2529F892BDD2FA DA : USB : HIGH-SPEED Boot done! Patch Level : PPR1.180610.011 Ver. CodeName : REL Ver. Release : 9 Sec. Patch : 2020-03-05 Product Manfct : OPPO Build Time : 20.03.2020 Product Brand : OPPO Product Model : CPH1989 Product Info : CPH1989 Product Name : CPH1989 Product Device : OP4C4B SW OTA Version : CPH1989EX_11.A.15_0150_202003210242 Display ID : CPH1989EX_11_A.15 Display ID : CPH1989EX_11_A.15_200321 Kernel Info : 4.4.146 Backup sensetive data [ 15 ] Backup path : Backup\MT6771__C9A6E5282542D3EB9A2529F892BDD2FA\ [31] Read : NVRAM [12] Read : NVDATA [19] Read : PROINFO [32] Read : LK [11] Read : NVCFG [14] Read : PROTECT1 [15] Read : PROTECT2 [17] Read : PERSIST [0] Read : PRELOADER [16] Read : SECCFG [5] Read : OPPORESERVE1 [6] Read : OPPORESERVE2 [7] Read : OPPORESERVE3 Backup done! STORAGE : LifeStatus : UFS : OK! Done! Elapsed: 00:00:55 Operation : Reset Settings/Format FS [ v2.21 ] Mode : SMART RESET 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1632 (COM4) MODE : BOOTROM PORT : 4 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6771 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Sylvia TYPE : MODERN RAPHAEL BROM : MEID : 11FEBED26113CDEBAAF4C644A427212F BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : Oppo : F11-Reno2F | Manual : Disabled BROM : SOCID : E04A3018D8790E7E602CD9AD7581C16D6CEAF19BD4110AEF7F 1E7E58F3BFBA39 BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6771 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : MT6752 EMI : SRC : preloader_oppo6771.bin EMI : CNT : 001A EMI : [00] : eMMC : LP_DDR4X : ID : 150100445636444D42 : VEN : SAMSUNG | DEV : DV6DMB : RAM : [ 4.00 GB ] EMI : [01] : eUFS : LP_DDR4X : DEV : KM5V8001DM-B622 : RAM : [ 4.00 GB ] EMI : [02] : eMMC : LP_DDR4X : ID : 150100335636434D42 : VEN : SAMSUNG | DEV : 3V6CMB : RAM : [ 6.00 GB ] EMI : [03] : eUFS : LP_DDR4X : DEV : KM5V7001DM-B621 : RAM : [ 4.00 GB ] EMI : [04] : eMMC : LP_DDR4X : ID : 150100334836434142 : VEN : SAMSUNG | DEV : 3H6CAB : RAM : [ 6.00 GB ] EMI : [05] : eMMC : LP_DDR4X : ID : 90014A68433861503E : VEN : HYNIX | DEV : hC8aP> : RAM : [ 6.00 GB ] EMI : [06] : eMMC : LP_DDR4X : ID : 13014E53304A394B39 : VEN : MICRON | DEV : S0J9K9 : RAM : [ 4.00 GB ] EMI : [07] : eMMC : LP_DDR4X : ID : 150100444836444142 : VEN : SAMSUNG | DEV : DH6DAB : RAM : [ 4.00 GB ] EMI : [08] : eMMC : LP_DDR4X : ID : 90014A68433861503E : VEN : HYNIX | DEV : hC8aP> : RAM : [ 4.00 GB ] EMI : [09] : eUFS : LP_DDR4X : DEV : MT128GASAO4U21 : RAM : [ 6.00 GB ] EMI : [0A] : eUFS : LP_DDR4X : DEV : MT128GASAO4U21 : RAM : [ 8.00 GB ] EMI : [0B] : eMMC : LP_DDR4X : ID : 13014E53304A394B38 : VEN : MICRON | DEV : S0J9K8 : RAM : [ 4.00 GB ] EMI : [0C] : eMMC : LP_DDR4X : ID : 13014E53304A394D39 : VEN : MICRON | DEV : S0J9M9 : RAM : [ 6.00 GB ] EMI : [0D] : eMMC : LP_DDR4X : ID : 13014E53304A394438 : VEN : MICRON | DEV : S0J9D8 : RAM : [ 4.00 GB ] EMI : [0E] : eUFS : LP_DDR4X : DEV : KM2B8001CM-BB01 : RAM : [ 6.00 GB ] EMI : [0F] : eMMC : LP_DDR4X : ID : 450100444134313238 : VEN : SANDISK | DEV : DA4128 : RAM : [ 4.00 GB ] EMI : [10] : eUFS : LP_DDR4X : DEV : KM8V7001JM-B810 : RAM : [ 8.00 GB ] EMI : [11] : eUFS : LP_DDR4X : DEV : KM2V8001CM-B707 : RAM : [ 6.00 GB ] EMI : [12] : eUFS : LP_DDR4X : DEV : KM8B8001JM-BC01 : RAM : [ 8.00 GB ] EMI : [13] : eUFS : LP_DDR4X : DEV : H9HQ22AECMMDAR : RAM : [ 6.00 GB ] EMI : [14] : eUFS : LP_DDR4X : DEV : KM8V8001JM-B813 : RAM : [ 8.00 GB ] EMI : [15] : eUFS : LP_DDR4X : DEV : MT128GASAO4U21 : RAM : [ 4.00 GB ] EMI : [16] : eUFS : LP_DDR4X : DEV : H28S8Q302CMR : RAM : [ 6.00 GB ] EMI : [17] : eUFS : LP_DDR4X : DEV : H9HQ16AFAMMDAR : RAM : [ 8.00 GB ] EMI : [18] : eUFS : LP_DDR4X : DEV : H9HQ22AFAMMDAR : RAM : [ 8.00 GB ] EMI : [19] : DRAM : LP_DDR4X : ID : NOT_DEFINED : VEN : UNKNOWN | DEV : : RAM : [ 6.00 GB ] EMI : Init EMI from PRELOADER EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00039000 [ 228.00 KB ] DRAM: 0x200000000 [ 8.00 GB ] UFS: CE014B4D3856373030314A4D2D423831 UFS: VEN : 0x01CE VID : KM8V7001JM-B81 IFW : 0900 LU0 : 0x00400000 [ 4.00 MB ] LU1 : 0x00400000 [ 4.00 MB ] LU2 : 0x1DCB000000 [ 119.17 GB ] FSN : 00330039006500620039003100330033 REG : 0x101010000 CHIP : MT6771 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : C9A6E5282542D3EB9A2529F892BDD2FA DA : USB : HIGH-SPEED Boot done! SmartInfo : 0x815757 Format Ok : USERDATA Format Ok : CACHE Format Ok : RESET PROTECTION Format Ok : USERDATA Done! Elapsed: 00:00:50 Reconnect Power/Cable! |
