04-18-2008, 18:26 | #1 (permalink) |
No Life Poster Join Date: May 2006 Location: Sambrial (Sialkot)
Member: 282066 Status: Offline Sonork: 100.1590696 Thanks Meter: 569 | Benq-siemens M300 Unlock problem? after unlock M300 still shows "invalid sim card" where i am roung please help me check log COM5 [VCP0] selected Device: BenQ M300, TCM Tchibo Checking data, wait... Action: unlock Boot... Phone should be Switched OFF ! Connect test-point to Ground ! Press Power button now ! Connecting... Disconnect test-point ! Boot Done Check Connection... Check Connection Done Set Baud... 812500 Set Baud Done Check Flash... Check Flash Done Check Parameters... Flash: 0089:885500010001 file saved: C:\Program Files\InfinityBox\BModule\backup_eeprom-00_20080415-204528.3AF.bin Check Parameters Done Check Space... Flash: 0089:885500010001 flash: Intel 28F640W30-B B 8Mb Check Space Done Check Data... Check Data Done Erasing... erase operation not required Erasing Done Writing... Flash: 0089:885500010001 Writing Done Finished, time used: 26 sec Remove/Install battery now ! |
04-18-2008, 21:20 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Try to make this: 1. insert wrong sim card 2. power-on phone 3. enter any code 4. power-off phone (don't remove battery) 5. make unlock again |
04-19-2008, 05:01 | #3 (permalink) | |
Member: 282066 Status: Offline Sonork: 100.1590696 Thanks Meter: 569 | Quote:
hello i did as you said but result is same ...............unlocking proses is ok but phone is still "invalid sim card" | |
04-19-2008, 06:35 | #4 (permalink) |
Member: 282066 Status: Offline Sonork: 100.1590696 Thanks Meter: 569 | i try again now log is diffirent COM5 [VCP0] selected Device: BenQ M300, TCM Tchibo Checking data, wait... Action: unlock Boot... Phone should be Switched OFF ! Connect test-point to Ground ! Press Power button now ! Connecting... Disconnect test-point ! Boot Done Check Connection... Check Connection Done Set Baud... 812500 Set Baud Done Check Flash... Check Flash Done Check Parameters... Flash: 0089:885500010001 file saved: C:\Program Files\InfinityBox\BModule\backup_eeprom-00_20080415-232250.3AF.bin error: not locked or unknown eeprom Check Parameters Fail Finished, time used: 24 sec Remove/Install battery now ! |
11-02-2014, 12:38 | #6 (permalink) |
Member: 282066 Status: Offline Sonork: 100.1590696 Thanks Meter: 569 | hello infinity team this is my old post today i find benq m300 with invald simcard after sp unlock set still ask invalid sim card i flashed it with other package (main+lp+flex v37/v21/v14) all same after unlock still locked i think this m300 model not unlock by anyone with infinity give me prof if i am wrong |
Benq Siemens EF81 unlocking without problems :) | wgmmmx | Z3X-Team Products | 9 | 01-16-2013 12:55 |
BenQ Siemens E61 Mic Problem* 10000000% | nerobdms™ | Siemens Hardware Repair Area | 1 | 01-11-2010 15:23 |
BenQ Siemens EF61 unlock problem | Kashif Khan | Infinity-Box | 1 | 04-29-2008 14:06 |
New benq siemens a38 unlock? | to_deal_with | VygisToolbox | 14 | 03-24-2007 20:26 |
" benq siemens e61 unlock?? " | afra.com | E-Gold Based Phones | 4 | 07-15-2006 12:01 |
