Benq M300 Flas Ok But POW Not On.....??? Benq M300 Flas Ok Phone No On Help............. Log........... COM5 [VCP0] selected Device: BenQ M300, TCM Tchibo Checking data, wait... Action: flash write "smart write" active Write: Firmware Write: Flex Write: Language Pack Write: Eeprom Boot... Phone should be Switched OFF ! Connect test-point to Ground ! Press Power button now ! Connecting... Disconnect test-point ! Boot Done Check Connection... Check Connection Done Set Baud... 812500 Set Baud Done Check Flash... Check Flash Done Check Parameters... Check Parameters Done Check Space... Flash: 0089:885500010001 flash: Intel 28F640W30-B B 8Mb Check Space Done Check Data... Check Data Done Erasing... erase operation not required Erasing Done Writing... Write: Firmware Flash: 0089:885500010001 flash: Intel 28F640W30-B B 8Mb Write: Flex flash: Intel 28F640W30-B B 8Mb Write: Language Pack flash: Intel 28F640W30-B B 8Mb Write: Eeprom flash: Intel 28F640W30-B B 8Mb Writing Done Finished, time used: 110 sec Remove/Install battery now ! |
Hello, What is initial phone state ? Is it was dead or good working phone ? Did you tried to use different version flash files sets (Main + LP + Flex the same version) ? |
What is initial phone state ?dead.Did you tried to use different version flash files. no (Main + LP + Flex the same version) yes same. |
So... 1. try to use different files sets 2. if still no luck after several tries and phone can't power on: open phone and check it's hardware |
