benq siemens A38 unlock problam benq siemens A38 unlock problam with infinity box i have try test point & cabal bat not suscsec log hare COM38 [VCP4] selected module v1.33 Device: O2X1i,O2XLI Checking data, wait... Action: unlock Boot... Phone should be Switched OFF ! Connect test-point to Ground ! Press Power button now ! Connecting... Disconnect test-point ! Boot Done Check Connection... Check Connection Done Set Baud... Set Baud Done Check Flash... Check Flash Done Check Parameters... Flash: 0001:227E221D2200 prosesc in check Parameters no err no go in ago prosesc only show in Check Parameters... Flash: 0001:227E221D2200 ane solution???? |
why u use infinity try with martech infinity is good for other |
1 Attachment(s) hi bro just download eprom file from support and flassh and ur phone should be unlok test many time..... go try it... Infinity support try to write this eprom file... |
You must select correct model !!! |
