06-07-2010, 15:19 | #1 (permalink) |
Freak Poster Join Date: Jan 2008 Age: 40
Member: 691960 Status: Offline Sonork: 100.1592294 Thanks Meter: 145 | Big problem cant boot lg kp110 with rx tx NOW WHAT SHOULD I DO An other thing is that i didnt worked with infinity rx tx cable b4 and i also do not have any pinfinder box but here i think i do not need any pinfinder rit HELP ME GUYS............. |
06-07-2010, 17:29 | #4 (permalink) | |
No Life Poster Join Date: Nov 2008 Location: gsm hosting
Member: 907098 Status: Offline Sonork: 100.1601140 Thanks Meter: 705 | Quote:
06-08-2010, 08:05 | #7 (permalink) |
No Life Poster Join Date: May 2007 Location: InsidE AndroiD Age: 37
Member: 503161 Status: Offline Sonork: 100.1584069 Thanks Meter: 473 | Brother !! I know there is some problem while connecting this phone but you need fully charged battery and good timing as the soft says press and hold power button !!! try this once more good luck br |
06-08-2010, 09:22 | #9 (permalink) |
Member: 503161 Status: Offline Sonork: 100.1584069 Thanks Meter: 473 | is your cable working??? well need to test your cable to another phone so what else can be there?? might be water inside - due to that not connecting clean your pcb with petrol or ctc- then check but be sure of ur cable must be 10/10 ok check it please br Last edited by azeem781986; 06-08-2010 at 09:22. Reason: pcb spelled correctly |
06-08-2010, 12:46 | #10 (permalink) | |
Member: 691960 Status: Offline Sonork: 100.1592294 Thanks Meter: 145 | Quote:
k i will try........................ | |
06-10-2010, 05:32 | #12 (permalink) | |
You must connect 3 wires from RJ45 to phone: Rx/Tx/Gnd Here is an instruction how to get cable/pinout information: 1. be sure that you have downloaded and installed latest Infinity-Box Pinouts update: Infinity-Box - News 2. run Infinity-Box Shell 3. select required model 4. see detailed information about cable/pinout (Rx/Tx/Gnd pins and other information) Here is an example of information given by Infinity-Box Shell: RJ45 connector pinout: Here is an information how to build your own cable: FAQ: Frequently Asked Questions, cables/pinouts, supported models - GSM-Forum | |
HELP: Problem with 5110 | Xabi | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-16-1999 00:44 |
Really big favour! | MiMiR the WiseMan | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 06-18-1999 03:21 |
Netmonitor with FBus???? | ratzfatz | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 06-09-1999 17:04 |
