Old 09-16-2005, 20:11   #1 (permalink)
Member: 96434
philips 568 cable??
hi all,
im trying to unlock philips 568 with g50 cable but it doesnt respond. can anyone help here
thanks
Old 09-16-2005, 20:16   #2 (permalink)
Member: 47236
Thanks Meter: 58
i have the same problem
cable is for g50 but my be problem is in soft
Old 09-16-2005, 20:34   #3 (permalink)
mtony969's Avatar
Member: 24552
Thanks Meter: 13
There are cables and cables some g50 dont work good quility cable needed
Old 09-16-2005, 20:54   #4 (permalink)
Member: 47236
Thanks Meter: 58
i am using cable that came with box
and i already unlocked 10 pices, but now 2 pices came back from them relocked and no connection with box
Old 09-17-2005, 10:54   #5 (permalink)
tersace's Avatar
Member: 44483
Thanks Meter: 4
I have same problem, I ma using the G50(b) cable that came with the box, any Ideas?
Old 09-17-2005, 11:03   #6 (permalink)
coolmax's Avatar
Member: 157118
Thanks Meter: 156
cut some rubber of the cable and then try it
Old 09-17-2005, 11:07   #7 (permalink)
tersace's Avatar
Member: 44483
Thanks Meter: 4
Phillips 568 is not like Moto C115, the conector in the phone is "flush" so cutting rubber won't make a difference.
Old 09-19-2005, 11:45   #8 (permalink)
Member: 130995
Thanks Meter: 35,227
Hi,
In fact, rubber cutting will make a difference. It's need to use cable with 4 metal pins (with "G50" mark") and cut rubber to be sure that cable inserted into phone completely.
Old 09-19-2005, 19:30   #9 (permalink)
tersace's Avatar
Member: 44483
Thanks Meter: 4
My cable goes all the way into the phone, the cable is working as I have used it to unlock other phones. I don't have the phone anymore as it is a customers phone and they have took it back. I will try again when I get another one to unlock.
Old 09-21-2005, 22:14   #10 (permalink)
Member: 4217
Thanks Meter: 28
Any solution for this? have same problem and know the g50 cable is workin fine.
have completely cut the plastic back so cable is fitting well but still no joy?
Old 09-22-2005, 11:38   #11 (permalink)
davidjollie's Avatar
Member: 11228
Thanks Meter: 32
try this
hi capt. calamity
i used unibox cable and cut back plastic or post imei in code section very quick return of unlock code....same day!
DJ
cable philips 568 !!!!!!! ayyoub225 FuriousGold 5 04-19-2010 13:04
which is the right cable for philips 568 risan FuriousGold 3 10-05-2007 13:20
philips 568 cable not working zata222 Redbox 5 09-26-2005 20:40
Philips 568 Flasher !!! UFoTeaM UfoTools 8 04-20-2005 23:19
Page generated in 0.20357 seconds with 9 queries
