bird v750 unlocked via infinity bird v750 successful unlocked via mmodule v2.32 , thank you infinity: COM5 [VCP0] selected Device: Bird-V750 Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: "sp-unlock" unlock method: standard Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6226:8A02:8A01]... CPU: MT6226 chip: 0031:CAC1:A842 boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 98007500000002:2BEA0000000000 flash: AMD/Fujitsu std [T 0008x004000 00FFx020000] 32Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud... 921600 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area#1 is Ok security area#1 backup saved: D:\Program Files\InfinityBox\MModule\backup_security\id.71FC7 3B7.[MX2007B9_GUYANA_PCB01_GPRS_MT6226_S01.V1_00_01_M08 0226GUY-V42-I05.BIN_14424A66].rpl identification#1 detection finished device-id: 71FC73B7 identification#1 protocol ver: 04 ver. sw1: MX2007B9_GUYANA_PCB01_GPRS_MT6226_S01.V1_00_01_M08 0226GUY-V42-I05.BIN ver. sw2: V1.00.01_M080226GUY-V42-I05, 99B5BDEB ffs offset/size: 01C00000/00400000 detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... reading: eeprom[MX2007B9_GUYANA_PCB01_GPRS_MT6226_S01.V1_00_01_M08 0226GUY-V42-I05.BIN]... file saved: D:\Program Files\InfinityBox\MModule\bird_v750\eeprom[MX2007B9_GUYANA_PCB01_GPRS_MT6226_S01.V1_00_01_M08 0226GUY-V42-I05.BIN]_20080916-144331.B0E.bin flash: 98007500000002:2BEA0000000000 Backup required data Done Patch required data... detection procedure, wait... detection procedure completed detection procedure, wait... detection procedure completed Patch required data Done Special operation... Special operation Done Write... flash: 98007500000002:2BEA0000000000 Write: eeprom Write Done Finalization... Finalization Done file saved: D:\Program Files\InfinityBox\MModule\backup_security\system_l og_71FC73B7_MX2007B9_GUYANA_PCB01_GPRS_MT6226_S01. V1_00_01_M080226GUY-V42-I05.BIN_14424A66_20080916-144817.B0X.bin Finished, time used: 426 sec Remove/Install battery now ! |
Thank you very much for test report ! Each test report with attached logs is very important for us so we can see how is Infinity-Box software works and what is possible problems and successfully done work. |
what cable you use please help |
use pinfinder from infinity |
@sweetboy Here is an instruction how to get cable/pinout information: 1. be sure that you have downloaded and installed latest Infinity-Box Pinouts update 2. run Infinity-Box Shell 3. select required model 4. see detailed information about cable/pinout http://www.infinity-box.biz/download...shell_v112.jpg Here is information how to build your own cable: http:///vbb/showthread.php?t=342807 |
