Old 03-08-2008, 11:04   #1 (permalink)
EMOTION BBSR's Avatar
Member: 194285
Thanks Meter: 53
Bleu 245x Dead
PHONE IS A BRAND NEW PHONE PHONE WAS LOCK
NOW DEAD
read full flash
COM3 [VCP0] selected
Checking data, wait...
Connect...
Press Power button now !
Connect Ok
Boot...
Boot Ok
Set baud...
115200
Set baud Ok
Read info...
flash: BF7353FFFF0052:00008500000000
flash: SST SST34HF3244/3284 U 4Mb
Read info Ok
Check flash...
Check flash Ok
Check space...
reading...
file saved: D:\Program Files\InfinityBox\PModule02\backup_part_1_of_1_200 80308-150159.70X.bin
Finished, remove/install battery now !
Time used: 495 sec
backup eeprom
Connect...
Connect Ok
Boot...
Boot Ok
Set baud...
115200
Set baud Ok
Read info...
Read info Ok
Check flash...
Check flash Ok
Check space...
reading...
file saved: D:\Program Files\InfinityBox\PModule02\backup_eeprom_calibrat ion__20080308-150401.70E.bin
reading...
file saved: D:\Program Files\InfinityBox\PModule02\backup_file_system__20 080308-150545.70F.bin
Time used: 127 sec
Connect...
Connect Ok
Boot...
Boot Ok
Set baud...
115200
Set baud Ok
Read info...
Read info Ok
Check flash...
Check flash Ok
Check space...
reading...
file saved: D:\Program Files\InfinityBox\PModule02\backup_eeprom_calibrat ion__20080308-150816.70E.bin
Check space Ok
Write...
Area: Firmware
Write: Firmware
error: no any expected answer
error: flash write error: 02000000:00002000
Write failed
Time used: 60 sec
Connect...
Connect Ok
Boot...
Boot Ok
Set baud...
115200
Set baud Ok
Read info...
Read info Ok
Check flash...
Check flash Ok
Check space...
reading...
file saved: D:\Program Files\InfinityBox\PModule02\backup_eeprom_calibrat ion__20080308-151024.70E.bin
Check space Ok
Write...
Area: eeprom
Write: eeprom
error: flash write error: 023F2000:00002000
Write failed
Time used: 66 sec
PHONE IS DEAD NOW
HELP NEED
Old 03-08-2008, 13:32   #2 (permalink)
Member: 194285
Thanks Meter: 53
not able to flash any file from support site. that is main, ffs and eeprom
also i am not able to write flash back up
it showing data error loading fail, probably damageed data file
Loading file v.02...
Loading failed, probably damaged data file.
also not able to write eeprom backup file
Connect...
Connect Ok
Boot...
Boot Ok
Set baud...
115200
Set baud Ok
Read info...
Read info Ok
Check flash...
Check flash Ok
Check space...
reading...
file saved: d:\Program Files\InfinityBox\PModule02\backup_eeprom_calibrat ion__20080308-175652.70E.bin
Check space Ok
Write...
Area: eeprom
Write: eeprom
Write Ok
Close...
Close Ok
Restart...
Restart Ok
Time used: 16 sec
Old 03-08-2008, 20:44   #3 (permalink)
Member: 130995
Thanks Meter: 35,227
Hello,
Download latest PModule02 from support area and try again.
btw, what was the reason to flash phone ?
Unlock function is not released yet for this model, flashing not unlock phone.
Old 03-09-2008, 10:30   #4 (permalink)
Member: 194285
Thanks Meter: 53
06 Mar 2008: "PModule02" v1.12
i am using this verson
Old 03-10-2008, 15:10   #5 (permalink)
Member: 130995
As I can see eeprom was written w/o problems.
Please, repeat firmware write process.
In case of any problems send flash backup to [email protected] and we will prepare file
Old 03-12-2008, 02:41   #6 (permalink)
Member: 194285
Thanks Meter: 53
flash backup sended to support. please help
Old 07-29-2008, 16:02   #7 (permalink)
b12345's Avatar
Member: 758310
Sonork: 100.1601610
Thanks Meter: 71
hello frnd had yu get yur solution in 245x
Old 07-31-2008, 04:23   #8 (permalink)
Member: 194285
Thanks Meter: 53
no yet. may be infinity will update this model later. waiting for that
Old 07-31-2008, 04:41   #9 (permalink)
akhil_bbsr's Avatar
Member: 271478
Sonork: 1590868
Thanks Meter: 1,070
Originally Posted by infinitysupport View Post
hello,
Download Latest Pmodule02 From Support Area And Try Again.
Btw, What Was The Reason To Flash Phone ?
Unlock Function Is Not Released Yet For This Model, Flashing Not Unlock Phone.
Ur Correct Infinity Team This Model Is Not Supported..... I Think My Dear@e_motion Has Mistaken...hope...unlocking Of This Model Will Support Soon...br.
bleu 245x dead shashankmobile ET-BoX 6 01-06-2013 19:26
bleu 245x dead after flash. sunny_gsm Infinity-Box 7 05-27-2011 18:03
bleu-245x dead veerpreet Infinity-Box 1 11-26-2008 16:54
bleu 245x dead accurate Infinity-Box 0 06-30-2008 11:23
bleu 245x dead accurate Infinity-Box 0 06-25-2008 12:35
Page generated in 0.18051 seconds with 9 queries
