03-23-2008, 12:21 | #3 (permalink) |
Registered User Join Date: Mar 2007 Location: jodhpur Age: 51
Member: 468435 Status: Offline Thanks Meter: 14 | Blue 245x Dead LOG FILE COM8 [VCP0] selected Checking data, wait... Phone should be Switched OFF ! Connect... Press Power button now ! Connect Ok Boot... Boot Ok Set baud... 115200 Set baud Ok Read info... flash: BF7353FFFF0052:00008500000000 flash: SST SST34HF3244/3284 U 4Mb Read info Ok Check flash... Check flash Ok Check space... reading... file saved: C:\Program Files\InfinityBox\PModule02\backup_eeprom_calibrat ion__20080323-164749.70E.bin Check space Ok Write... Area: Firmware flash: BF7353FFFF0052:00008500000000 Write: Firmware error: no any expected answer error: flash write error: 02000000:00002000 error: no any expected answer error: flash write error: 02000000:00002000 Write failed Finished, remove/install battery now ! Time used: 67 sec |
03-23-2008, 13:54 | #5 (permalink) |
Member: 468435 Status: Offline Thanks Meter: 14 | Not Success Log Here ==== log opened: [3/23/2008 4:52:19 PM] ==== Application: C:\Program Files\InfinityBox\PModule02\PModule02.exe Loading data, wait... [Infinity Box] v1.12 S/N: 0882:010E Current model: Bleu 151x Done Loading file v.02... Bleu-145x_repair_eeprom_01.70E.bin loaded Action: write flash "smart write" active skip: Firmware skip: File System skip: Language pack write: eeprom COM8 [VCP0] selected Checking data, wait... Phone should be Switched OFF ! Connect... Press Power button now ! Connect failed Finished, remove/install battery now ! Time used: 40 sec Current model: Bleu 245x Loading file v.02... Bleu-245x_repair_eeprom_01.70E.bin loaded Action: write flash "smart write" active skip: Firmware skip: File System skip: Language pack write: eeprom COM8 [VCP0] selected Checking data, wait... Phone should be Switched OFF ! Connect... Press Power button now ! Connect Ok Boot... Boot Ok Set baud... 115200 Set baud Ok Read info... flash: BF7353FFFF0052:00008500000000 flash: SST SST34HF3244/3284 U 4Mb Read info Ok Check flash... Check flash Ok Check space... reading... file saved: C:\Program Files\InfinityBox\PModule02\backup_eeprom_calibrat ion__20080323-165526.70E.bin Check space Ok Write... Area: eeprom flash: BF7353FFFF0052:00008500000000 Write: eeprom error: no any expected answer error: flash write error: 023F2000:00002000 Write failed Finished, remove/install battery now ! Time used: 59 sec |
05-20-2008, 18:33 | #9 (permalink) |
No Life Poster Join Date: Sep 2007 Location: chattisgarh,India
Member: 578941 Status: Offline Thanks Meter: 108 | COM4 [VCP1] selected Checking data, wait... Phone should be Switched OFF ! Connect... Press Power button now ! Connect Ok Boot... Boot Ok Set baud... 115200 Set baud Ok Read info... flash: BF7353FFFF0052:00008500000000 flash: SST SST34HF3244/3284 U 4Mb Read info Ok Check flash... Check flash Ok Check space... Check space Ok Write... Area: Firmware flash: BF7353FFFF0052:00008500000000 Write: Firmware error: no any expected answer error: flash write error: 02000000:00002000 Write failed Finished, remove/install battery now ! Time used: 25 sec i got this same problem This set is locked with idea network in india. is it build so that we cant flash it coz it give write error in message in same address |
06-06-2008, 11:56 | #10 (permalink) |
No Life Poster Join Date: May 2003
Member: 28004 Status: Offline Sonork: 100.1601142 Thanks Meter: 770 | i have a dead 245x , when i try to flash the set with infinity i get this error .. what could be the problem ? COM7 [VCP0] selected Checking data, wait... Phone should be Switched OFF ! Connect... Press Power button now ! Connect Ok Boot... Boot failed Finished, remove/install battery now ! Time used: 7 sec |
06-09-2008, 19:21 | #11 (permalink) |
Freak Poster Join Date: Aug 2007 Location: INDIA
Member: 566051 Status: Offline Thanks Meter: 105 | In all casses Infinity flash file problem.My 2 set bleu 151x became dead.Same flashing problem. (Write: Firmware error: no any expected answer error: flash write error: 02000000:00002000 Write failed ) I cant understend Plz help Infinity team |
06-10-2008, 20:15 | #12 (permalink) |
Member: 28004 Status: Offline Sonork: 100.1601142 Thanks Meter: 770 | i have tried in many sets 245x with infinity , all the time it gives error , i think until now it is not possible with infinity... let us wait some more time .. thanks |
06-17-2008, 15:13 | #13 (permalink) | |
Freak Poster Join Date: Sep 2007 Age: 47
Member: 597666 Status: Offline Thanks Meter: 286 | Quote:
COM2 [Serial2] selected Checking data, wait... Phone should be Switched OFF ! Connect... Press Power button now ! Connect Ok Boot... Boot Ok Set baud... 115200 Set baud Ok Read info... flash: BF7353FFFF0052:00008500000000 flash: SST SST34HF3244/3284 U 4Mb Read info Ok Check flash... Check flash Ok Check space... reading... file saved: C:\Program Files\InfinityBox\PModule02\backup_eeprom_calibrat ion__20080617-193508.70E.bin Check space Ok Write... Area: Firmware flash: BF7353FFFF0052:00008500000000 Write: Firmware error: no any expected answer error: flash write error: 02000000:00002000 Write failed Finished, remove/install battery now ! Time used: 37 sec | |
07-31-2008, 18:04 | #15 (permalink) |
No Life Poster Join Date: Apr 2008
Member: 758310 Status: Offline Sonork: 100.1601610 Thanks Meter: 71 | please help me Connect... Press Power button now ! Connect Ok Boot... Boot Ok Set baud... 115200 Set baud Ok Read info... flash: BF7353FFFF0052:00008500000000 flash: BF7353FFFF0052:00008500000000 flash: SST SST34HF3244/3284 U 4Mb Read info Ok Check flash... Check flash Ok Check space... Check space Ok Write... Area: Firmware flash: BF7353FFFF0052:00008500000000 flash: BF7353FFFF0052:00008500000000 Write: Firmware error: no any expected answer error: flash write error: 02000000:00002000 Write failed Finished, remove/install battery now ! Time used: 35 sec sir what can i do at this problem |
Blue 245x | rajumobile | Infinity-Box | 20 | 04-10-2014 17:03 |
>>> Dead Blue 245x Recovered By ET <<< | zeel_zeel | ET-BoX | 2 | 04-17-2009 06:45 |
blue 245x 145x unlock ? | doller | Infinity-Box | 4 | 04-24-2008 21:22 |
blue 245x pinout | jobykjoseph | Various | 1 | 04-09-2008 17:23 |
