07-19-2009, 12:50 | #1 (permalink) |
Freak Poster Join Date: Mar 2009
Member: 983750 Status: Offline Thanks Meter: 26 | blue 245x unlocking sir i want to sp unlock bleu 245x i get 2 flash files from support area Bleu-245x_CALCOMP-G250-VER-B01.03-20070808_(245x_32+8)_ver2.70M COM2 [VCP0] selected Checking data, wait... Phone should be Switched OFF ! Connect... Press Power button now ! Connect Ok Boot... Boot Ok Set baud... 115200 Set baud Ok Read info... flash: BF7353FFFF0052:00008500000000 flash: SST SST34HF3244/3284 U 4Mb Read info Ok Check flash... Check flash Ok Check space... reading... file saved: C:\Program Files\InfinityBox\PModule02\eeprom_calibration__20 090606-220251.70E.bin Check space Ok Write... Area: Firmware flash: BF7353FFFF0052:00008500000000 Write: Firmware error: no any expected answer error: flash write error: 02000000:00002000 Write failed Finished, remove/install battery now ! Time used: 55 sec and i try with another file Bleu-245x_CALCOMP-G250-VER-B01.03-20070808_(245x_32+8).70M COM2 [VCP0] selected Checking data, wait... Phone should be Switched OFF ! Connect... Press Power button now ! Connect Ok Boot... Boot Ok Set baud... 115200 Set baud Ok Read info... flash: BF7353FFFF0052:00008500000000 flash: SST SST34HF3244/3284 U 4Mb Read info Ok Check flash... Check flash Ok Check space... reading... file saved: C:\Program Files\InfinityBox\PModule02\eeprom_calibration__20 090606-220356.70E.bin Check space Ok Write... Area: Firmware flash: BF7353FFFF0052:00008500000000 Write: Firmware Write Ok Close... Close Ok Restart... Restart Ok Finished, remove/install battery now ! Time used: 222 sec but my set not power on what to do |
The Following User Says Thank You to pankaj_gsm For This Useful Post: |
blue 245x unlocking | pankaj_gsm | Infinity-Box | 5 | 06-28-2009 11:58 |
need blue 245x unlocking | inderje | Infinity-Box | 0 | 04-29-2009 11:10 |
Need CPF II Blue 245x Unlock File | 5700 | CPF-BOX Ⅱ | 2 | 04-10-2009 14:00 |
blue 245x 145x unlock ? | doller | Infinity-Box | 4 | 04-24-2008 21:22 |
