Old 05-10-2008, 15:06   #1 (permalink)
Imrankhan's Avatar
Member: 573962
Sonork: 100.1603021
Thanks Meter: 480
blue tooth 2.0 bad software
hallo infinity team
my blue tooth 2.0 bad software.
after repair eprom and write firmware set on but no disply.
here is eprom file name---
MOBILEDEN25_06B_PCB01_GPRS_MT6225_S00[1].M608_V_1_07_P1HXM25BC30_CN__Cect-LV918_eeprom_03.B0E.bin
and here is fimware name----
MOBILEDEN25_06B_PCB01_GPRS_MT6225_S00[1].M608_V_1_07_P1HXM25BC30_CN__16m_Ru_Fr_En_Th_Vn_Ar _w_eeprom.B0M.bin
here is detail information log befor flashing
COM5 [VCP1] selected
Device: Autodetect 6205-6227 NOR
Checking data, wait...
eeprom backup enabled, it may takes several minutes !
Action: read/check detailed information
Boot...
19200 fixed
Connecting, wait...
Initializing[6225:8A03:8A00]...
CPU: MT6225
high speed boot enabled
chip: 0001:B703:000A
boot step size: 0400
Release Power button now !
Boot Done
Initialize...
flash: 2088C4FFFFFFFF:2088C400000000
flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb
detecting chip #01 in region #00...
number of flash chip/regions detected: 02/01
Initialize Done
Set baud...
460800
Set baud Done
Initialize bootcode...
Initialize bootcode Done
Check firmware integrity...
device parameters autodetection in progress..
it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
detect device identification#1...
detection phase #1...
detect device identification#1 finished
identification#1 structure: 2nd [standard] generation
identification#1 protocol ver: 04
ver. sw1: MOBILEDEN25_06B_PCB01_GPRS_MT6225_S00.M608_V_1_17_ P1HXM25BC30_ST_CN.BIN
ver. sw2: M608_V_1.17_P1HxM25BC30_ST_CN, 00000000
ffs offset/size: 00E00000/00200000
detect device identification#2...
warning: optional information not found,
if phone works well just ignore this warning
detect device identification#2 finished
detecting eeprom/ffs area in 1 chip(s)...
standard eeprom/ffs offset detected: 00E00000
checking area[00000000]: 00000000-00FFFFFF...
eeprom/ffs found near: 00E00000
detecting eeprom/ffs size...
eeprom/ffs size: 00200000
ffs chip: 00
eeprom/ffs area: 00000000:00E00000-00FFFFFF
detecting ffs structure pass 1...
detect standard fat location pass #1...
detect standard fat offset pass #1...
detect standard fat data...
fat layout detection complete
ffs element #1 detected ok
detecting ffs structure pass 2...
ffs element #2 detected ok
Check firmware integrity Done
Check firmware content...
Check firmware content Done
Backup required data...
Finished, time used: 143 sec
Remove/Install battery now !
pls help me
Old 05-11-2008, 21:45   #2 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
you used wrong file for flashing.
your firmware version is MOBILEDEN25_06B_PCB01_GPRS_MT6225_S00.M608_V_1_17_ P1HXM25BC30_ST_CN
but you used MOBILEDEN25_06B_PCB01_GPRS_MT6225_S00[1].M608_V_1_07_P1HXM25BC30_CN
Old 05-12-2008, 01:44   #3 (permalink)
Member: 137980
Thanks Meter: 168
-SIR I HAVE SAME PROBLEM PLEASE TELL ME HOW TO SOLVE THIS PROBLEM & whitc file i select for flash
Old 05-12-2008, 08:27   #4 (permalink)
Imrankhan's Avatar
Member: 573962
Sonork: 100.1603021
Thanks Meter: 480
hello!
but same file not found in support area.
pls tell me similer file name.
Old 05-12-2008, 08:39   #5 (permalink)
.::ricky rayya::.'s Avatar
Member: 254397
Thanks Meter: 224
i have 7 peace bluetooth 2.0 i try flash with also file form support area 1 by 1 but some phone going 'white screen' or some 'bad software' after flashing.
we know infinity team is great but this modle not proper solution have infinity team. please update this modle.
..::RICKY RAYYA::..
Old 05-12-2008, 10:07   #6 (permalink)
Member: 270936
Thanks Meter: 33
yes what u said is rite, and am also holding the same bad software for the last four months in hand after trying all the flashes in the support site.still waiting for the best result.
Old 05-12-2008, 13:31   #7 (permalink)
Imrankhan's Avatar
Member: 573962
Sonork: 100.1603021
Thanks Meter: 480
infinity team this is true????
what no solution this set.
pls reply .
Blue tooth 2.0 bad software after format nilan SpiderMan 3 05-15-2008 08:04
blue tooth mobile " bad software " IBMOBILES Chinese Cocktail 9 11-04-2007 11:34
Chines phone Blue Tooth 2.0 LV918 now_mobiles Infinity-Box 5 11-02-2007 16:24
Chinese Blue Tooth 2.0 Not Connecting sahil2000ind Infinity-Box 19 10-23-2007 12:30
Page generated in 0.26199 seconds with 10 queries
