10-14-2008, 01:50 | #1 (permalink) |
Freak Poster Join Date: Jul 2006 Location: egypt
Member: 309944 Status: Offline Sonork: 1628185 Thanks Meter: 40 | bluetooth 888 dr.lolo |
10-14-2008, 09:41 | #4 (permalink) |
Member: 309944 Status: Offline Sonork: 1628185 Thanks Meter: 40 | cos im using infinty box with pinfinder which i just bought and the supporter put this model in the list of phones that supported by the box .... so pinfinder read cpu as mt6205 while its written on cpu mt6226 .. so im asking is there somthing wrong with my box or not ? and asking where is the flash file on the site and which one should be givin to phone from the box support area ????????????? is it by name of cpu or as pinfinder sayes ???????? |
10-14-2008, 18:40 | #5 (permalink) | |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Quote:
If this phone has two SIM card slots- in most cases it has pair of MCUs: 6226- main (also called MCU_a), 6205- second (MCU_b) right now your pinfinder stopped searching on second MCU pinout. you must go to advanced settings and disable this pins. repeat search and this time it will stop on MCU_a. make "read full flash" for emergency case and then try to format FFS. first SAFE, if will not help- COMPLETE. if both format methods will not work for you perform flashing. here is a link how to search for correct flash file on support: http://forum.gsmhosting.com/vbb/showthread.php?t=499453 if you still have any question- please ask | |
i-Pmart BX Series RJ45 Cable Compatible For Bluetooth 888 CPU2 For Infinity Box | IPMART | ipmart WebShop | 0 | 07-08-2009 15:00 |
i-Pmart BX Series RJ45 Cable Compatible For Bluetooth 888 CPU1 For Infinity Box | IPMART | ipmart WebShop | 0 | 07-08-2009 15:00 |
CECT 888 Dual SIM Card Phone With Bluetooth - Silver | IPMART | ipmart WebShop | 0 | 12-23-2008 11:40 |
CECT 888 Dual SIM Card Phone With Bluetooth - Pink | IPMART | ipmart WebShop | 0 | 12-23-2008 11:40 |
DTV 888 Dual SIM Card Phone with DVB-T TV & Bluetooth | IPMART | ipmart WebShop | 0 | 11-22-2008 12:00 |
