03-06-2008, 14:58 | #1 (permalink) |
No Life Poster Join Date: Sep 2005 Location: repair shop Age: 44
Member: 181825 Status: Offline Thanks Meter: 199 | bluetooth a980 flash needed Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: repair security area Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6225:8A03:8A00]... CPU: MT6225 high speed boot enabled chip: 0001:8B03:0006 boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 01227E22202200:FFFFFF00000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #01 in region #00... flash: 01227E22202200:FFFFFF00000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 460800 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: 01227E22202200:FFFFFF00000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb Warning: probably flash chip empty, erased, incorrectly flashed or damaged. What to do: 1. go to software "Settings" page 2. set "Advanced chip detection method" box UN-CHECKED ! 3. make flash write operation If still no luck: send mail to support with detailed description of problem, attach the next files in your e-mail: 1. C:\Program Files\InfinityBox\ChineseMiracle\operation.log 2. C:\Program Files\InfinityBox\ChineseMiracle\cfi_***x_***x.bin detecting chip #01 in region #00... flash: 01227E22202200:FFFFFF00000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb it's time to stop: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... . detection phase #2... .................................................. .................................................. ............................ warning: identification#1 information not found, possible reasons: .old firmware type w/o identification#1 data .damaged firmware .damaged hardware if phone works fine just ignore this warning detect device identification#1 finished detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... flash: 01227E22202200:FFFFFF00000000 Backup required data Done Patch required data... Patch required data Done Special operation... Special operation Done Write... Write Done Finalization... Finalization Done Finished, time used: 60 sec Remove/Install battery now ! |
03-06-2008, 15:27 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, It looks like flash chip in your phone is completely erased. If you want to get flash file you must post here phone picture, in other case nobody can help you. |
03-06-2008, 21:48 | #4 (permalink) |
No Life Poster Join Date: Mar 2008 Location: infinity-box
Member: 720034 Status: Offline Thanks Meter: 213 | You can try to write several different MT6225 flash files and see results. If phone can Power-On with any of firmware but works not well you need to write firmware with similar (but little bit different) firmware name. |
The Following User Says Thank You to InfinityN For This Useful Post: |
ot-363a flash need | boliargsm | Alcatel TCL Phones and New Models | 1 | 03-29-2010 20:10 |
2700 flashing need help | ngaia | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 1 | 03-29-2010 11:48 |
Bluetooth A980 Pinouts ???? | zeel_zeel | Infinity-Box | 1 | 12-22-2008 16:52 |
Need Bluetooth M8800 Flash File Or Eprom File | Harkishan singh | Infinity-Box | 3 | 05-13-2008 19:43 |
Flash File for Chinese Phone Bluetooth 8928 badly needed.. | ASHRIFF | Infinity-Box | 1 | 12-30-2007 20:21 |
