05-08-2008, 02:00 | #1 (permalink) |
No Life Poster Join Date: Sep 2005 Location: algeria BBA BELIMOUR Age: 46
Member: 184351 Status: Offline Thanks Meter: 263 | blutooth 2 gsm mobile problem the phone is ok but it can't read the 2 sim cards simultaneously and he writes open sim b then searching for network then no thing happen just the first network of the sim a and when you go to the configuration open sim b it counts 1.2.3. but it returns to the menu with out opening the second sim is it normal or abnormal help my friends |
05-09-2008, 11:42 | #5 (permalink) | |
Member: 184351 Status: Offline Thanks Meter: 263 | Quote:
i have used the connector to communicate with the phone it is 18 pin connector keyboard top 1.........18 2: Gnd 7: Rx 9: Tx and i formatted it the cpu detected is mt6226BA but the problem is in the second sim it can't be opened and when i use each sim alone the phone read it without any problem what should i do ? thank you | |
05-09-2008, 11:53 | #6 (permalink) |
No Life Poster Join Date: Sep 2006
Member: 343326 Status: Offline Thanks Meter: 1,463 | Dear also check this link . . . . . Dual CPU. . . . For 2 sim . . . problem disscussion. |
05-09-2008, 13:14 | #7 (permalink) |
Member: 184351 Status: Offline Thanks Meter: 263 | thank you problem fixed after connecting to second cpu 6205 using rxb and txb making format ffs complete then rebuilding second imei using any imei phone is working good thank you for your help |
