03-26-2010, 23:18 | #1 (permalink) |
No Life Poster Join Date: Jan 2010 Location: Sydney Age: 37
Member: 1205146 Status: Offline Thanks Meter: 879 | Boost Mobile D-615 Unlock Help Needed Code: COM5 [VCP0] selected module v2.79 Action: read codes unlock method: read codes Model: Bost-Mobile-D615 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6219:8B02:8B01]... CPU: MT6219 chip: 0031:CDC1:E81E status: FF detected CPU: MT6226MA error: initialize step #3 failed Can not initialize test mode ! Possible reasons: 1. communication fault, repeat required operation 2. ffs/eeprom is serious damaged, use repair ffs/eeprom files or use other unlock/format method error: operation failed ! Finished, time used: 8 sec Remove/Install battery now ! Code: Action: read information Model: Bost-Mobile-D615 Checking data, wait... Phone should be Switched ON ! Connecting, wait... Phone detected, wait... Hardware version: MT6226M, E0 Hardware version: HWV1.0 Software version: V1.00.04_M070925AU1- Software date: 2005.04.12 Barcode: 011500097307 imei: 354885013267345 Finished, time used: 46 sec Power off phone now ! Code: COM5 [VCP0] selected module v2.79 Device: Bost-Mobile-D615 Checking data, wait... advanced flash detection enabled Action: read/check detailed information Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6219:8B02:8B01]... CPU: MT6219 detected CPU: MT6226MA chip: 0031:CDC1:E81E status: FF error: initialize EMI for BANK0 Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" Boot Fail Finished, time used: 25 sec Remove/Install battery now ! I know i'm using old version. but i have no access to support area. LITTLE MASTER |
03-28-2010, 17:29 | #3 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | You must pres and HOLD phone "power" button more long time. http://www.infinity-box.com/download...dule_v3.28.rar |
03-29-2010, 03:49 | #4 (permalink) |
Member: 1205146 Status: Offline Thanks Meter: 879 | Not working sir.. Still same error as before.. And i can't even read the FULL Flash. Is this CPU ID Supported .. Coz I checked now , the people who have unlocked this model that CPU ID is different .. LITTLE MASTER |
03-29-2010, 14:39 | #5 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Hello, Yes, this cpu is supported well during long time already. Also, what different CPU-ID you talk about exactly ? Just an example: CPU-ID is different for each phone, it's something like a cpu name, f.e. your name is "Little_Master", mine is "YellowBoss" but we are both this forum members. mow replace "forum members" with word "phone" and your and mine name with "CPU-ID value". What did you mean "can not read full flash" ? what is the problem exactly ? did you tried to follow my previous advice regarding "power" button ? |
04-08-2010, 04:28 | #6 (permalink) |
Member: 1205146 Status: Offline Thanks Meter: 879 | Happy Easter Sir ! Don't get angry. I bought the phone from customer just to get success of unlocking on this phone. Q:1 Also, what different CPU-ID you talk about exactly ? If you check this link: the CHIP is : chip: 0031:6A14:B80E http://forum.gsmhosting.com/vbb/4153967-post8.html If you check this link: the CHIP is chip: 0031:1041:B200 http://forum.gsmhosting.com/vbb/4057813-post1.html What did you mean "can not read full flash" ? It is just a information from me that, I can read General Info of phone , But if i try to do other operation , like; Unlock. Read Flash ETC , it's giving me error. what is the problem exactly ? did you tried to follow my previous advice regarding "power" button yes, I tried that , toooo many times with fully charged battery, But error: LITTLE MASTER |
04-08-2010, 18:00 | #7 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Hello, Thank you for information about different chip types. Please, let me know, how it was my previous explanation about CPU type ? Is it was clear enough or it's need to make better explanation ? If you still insist that "that" and "your" phones has different "CPU", here is more detailed explanation: Code: Initializing [6219:8B02:8B01]... CPU: MT6219 detected CPU: MT6226MA chip: 0031:CDC1:E81E green phone - unique phone id If you still can not read full flash from this phone with latest MModule, could you, please, try to find another cable (f.e. ordinary COM port cable) and try to us this other cable. |
04-08-2010, 23:39 | #8 (permalink) |
Member: 1205146 Status: Offline Thanks Meter: 879 | Thanks for your Reply, I'm not insisting that it's a different CPU, It was just my idea MAY BE it's different, But if u sure it is supported, then I'll try again and again with different cables, and will post the result for you. LITTLE MASTER |
04-09-2010, 12:31 | #9 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Hello, Please, keep me informed about results with different cables due to it's quite strange that this phone (that is quite old) can not be connected well at your side. |
BlackBerry 8520 unlock help needed | derk | FuriousGold | 3 | 04-08-2010 11:37 |
Boost Mobile Model D615 unlock Help ? | duyphuong | Various | 5 | 07-14-2008 09:06 |
A60 Virginn Mobile unlocking help needed | tical | Martech CLIP / Box / Key | 2 | 01-05-2006 22:18 |
3210 unlock help needed please!!! | HitMan | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 11-06-1999 01:27 |
