11-14-2007, 05:48 | #1 (permalink) |
Freak Poster Join Date: Dec 2006 Location: indonesia
Member: 412834 Status: Offline Thanks Meter: 215 | nokia 6300 Q7+ i have problem with my 6300 Q7+ the phone is restart if with simcard this the info Action: read information Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... Phone detected, wait... Hardware version: MT6226, E02 Software version: A7_NOKIA_NOBAHASA_V0 Software date: 2005.04.12 Barcode: 071301MT012345678901234567 10 imei: 356198012297778 Finished, time used: 4 sec Power off phone now ! but the phone is not work when read eeprom this the log COM18 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection active Action: read eeprom Boot... Press and HOLD Power button now ! baud autodetection active 19200 Connecting, wait... error: boot phase#2/1 failed Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" box. Boot Fail Finished, time used: 9 sec Remove/Install battery now ! and i want to format ffs is not wort to this the log COM18 [VCP0] selected Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 Initializing[6226:8A02]... error: initialize step#1 failed Can't initialize test mode ! Possible reasons: 1. communication fault, repeat required operation 2. eeprom serious damaged, use repair eeprom files or use other unlock/format method Operation failed ! Finished, time used: 35 sec Remove/Install battery now ! please help me t solved my problem thx |
11-14-2007, 07:56 | #3 (permalink) |
Member: 412834 Status: Offline Thanks Meter: 215 | same the problem can anyone have tested pinout? please share..... this the report COM18 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection active Action: reset Boot... Press and HOLD Power button now ! baud autodetection active 19200 Connecting, wait... error: boot phase#1 failed Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" box. Boot Fail Finished, time used: 6 sec Remove/Install battery now ! |
11-14-2007, 08:04 | #4 (permalink) | |
No Life Poster Join Date: Jul 2006 Location: U-A-E Dubai---->Pak
Member: 315789 Status: Offline Thanks Meter: 3,428 | Quote:
2 x 5 | |
11-14-2007, 17:16 | #6 (permalink) |
Freak Poster Join Date: Apr 2006 Location: Inside PM
Member: 258154 Status: Offline Thanks Meter: 319 | brother just open the phone the TX,RX,and GND points are just below MMC connectors solder the wire on points and just format FFS with infinity...no need to flash ur phone..100000%working solution and tested by me on 3phones.. Try and port UR Success Adampur Hawks |
11-16-2007, 23:30 | #7 (permalink) | |
Junior Member Join Date: Jul 2007 Age: 40
Member: 539657 Status: Offline Thanks Meter: 0 | nokia updates are free Quote:
11-16-2007, 23:54 | #8 (permalink) | |
richard200009 Junior Member Join Date: Jul 2007 Age: 23 Posts: 1 Member: 539657 Status: Online =============================== It's first message.... Could you, please, explain, what you talk about ? | |
nokia 6300 q7+ rx,tx points not working | sureshplaza | Chinese Models & Cloned Phones | 7 | 07-08-2008 10:29 |
chinese nokia 6300 Q7+ auto off with sim card repaired by infinity box | megatech10 | Chinese Models & Cloned Phones | 0 | 04-05-2008 06:09 |
chinese nokia 6300 q7 | murthyy | Chinese Models & Cloned Phones | 1 | 03-13-2008 08:22 |
Q7+ Nokia 6300 Repair | PARMATMA | Chinese Cocktail | 7 | 10-16-2007 14:24 |
chinese nokia 6300 Q7 | ahmad bashir | Chinese Cocktail | 1 | 10-04-2007 18:56 |
