06-04-2008, 07:53 | #1 (permalink) |
Freak Poster Join Date: Jul 2005 Age: 74
Member: 163019 Status: Offline Thanks Meter: 9 | Problem With Huawei T201 Please advise on how to Unlock T201. It seems responding but ends up giving the error below: COM3 [VCP0] selected Device: Huawei-T201 Checking data, wait... Action: unlock unlock method-1 Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... next part... error: can't run main loader: Finished, Remove/Install battery now ! Time used: 6 sec Please advise. |
06-04-2008, 12:46 | #3 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,228 | Hello, if you have some free time, please, try to read flash from this phone selection another models from Pana01 module. It may be that your phone can be booted as another models. Let's see results of this operation, then we will think what to do next. |
07-01-2008, 09:36 | #4 (permalink) | |
Insane Poster Join Date: Feb 2005 Location: Uganda Age: 60
Member: 117989 Status: Offline Thanks Meter: 5 | Quote:
It reads with model t128 but it can,t unlock neither flash | |
07-16-2008, 13:12 | #5 (permalink) | |
No Life Poster Join Date: Apr 2001 Location: AGADIR Morocco
Member: 3936 Status: Offline Thanks Meter: 237 | Quote:
regards | |
07-16-2008, 14:40 | #6 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,228 | Thanks for information. Also, when you will have another T201 on hands, please, try to use both software modules (old and new) and post here logs so we can check what is the problem. |
07-16-2008, 16:25 | #7 (permalink) |
Member: 3936 Status: Offline Thanks Meter: 237 | here find two logs for same phone tested first with version 1.50 no success but unlocked with version 1.42 please do not tell me to check cable like in a previous thread here http://forum.gsmhosting.com/vbb/showthread.php?t=561650 === log opened: [16/07/2008 12:46:24] ==== Application: C:\Program Files\InfinityBox\Pana01\Pana01.exe Loading data, wait... [Infinity Box] v1.50 S/N: Wait... Current model: Huawei-T201 Ready COM3 [VCP0] selected Device: Huawei-T201 Checking data, wait... Action: unlock unlock method-1 Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... next part... error: can't run main loader: Finished, Remove/Install battery now ! Time used: 7 sec ==== log opened: [16/07/2008 13:20:27] ==== Application: C:\Program Files\InfinityBox\Pana01\Pana01.exe Loading data, wait... [Infinity Box] v1.42 S/N: Wait... Current model: Coral-200 Ready Current model: Huawei-T201 COM3 [VCP0] selected Device: Huawei-T201 Checking data, wait... Action: unlock unlock method-1 Boot... Press and HOLD Power button now ! loading... boot answer: 01 Release Power button now Boot Done Set Baud... 460800 Set Baud Done Connecting... flash: 0001:011A Connecting Done Check hardware... flash chip supported Check hardware Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: C:\Program Files\InfinityBox\Pana01\backup_eeprom-sta_20080716-132108.B1E.bin loading data... data loaded reading [eeprom-sec]... file saved: C:\Program Files\InfinityBox\Pana01\backup_eeprom-sec_20080716-132112.B1E.bin reading [eeprom-complete]... file saved: C:\Program Files\InfinityBox\Pana01\backup_eeprom-complete_20080716-132116.B1E.bin reading [eeprom-dyn]... file saved: C:\Program Files\InfinityBox\Pana01\backup_eeprom-dyn_20080716-132118.B1E.bin reading additional data... done backup critical area Done Check memory... current status: 0 Check memory Done Write... Erasing: lock-area Writing: lock-area Write Done Finished, Remove/Install battery now ! Time used: 31 sec Unlock instruction: 1. Power-On phone 2. Enter code: 12345678 regards |
07-18-2008, 01:17 | #8 (permalink) |
No Life Poster Join Date: Sep 2005 Location: near Network Age: 48
Member: 185608 Status: Offline Thanks Meter: 592 | You are right I came on help,but you have finish. Friends use old version pana01(V1.46) for ex.100°/° New version have bugs with huawei T201. |
09-20-2008, 11:14 | #11 (permalink) |
No Life Poster Join Date: Feb 2004 Location: Dar es Salaam TANZANIA
Member: 53263 Status: Offline Sonork: gsm master Thanks Meter: 326 | COM1 [Serial0] selected Device: Huawei-T201 Checking data, wait... Action: unlock unlock method-1 Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... next part... error: can't run main loader: Finished, Remove/Install battery now ! Time used: 7 sec |
The Following User Says Thank You to MGT SOFTWARE For This Useful Post: |
09-20-2008, 13:42 | #13 (permalink) | |
Member: 163019 Status: Offline Thanks Meter: 9 | Quote:
Thanks,Wil try and see if it works. | |
09-23-2008, 18:34 | #14 (permalink) | |
Freak Poster Join Date: Nov 2005 Location: .:in to realyty:.
Member: 199469 Status: Offline Thanks Meter: 11 | Quote:
10-28-2008, 09:24 | #15 (permalink) |
Junior Member Join Date: Oct 2008
Member: 886134 Status: Offline Thanks Meter: 0 | Please Help My huawei t201 always show earphones when i switch on and on display says "HEADSET INSET''. I n this status l can not use the since i can not hear anything when a call comes, l tried to connect headsets but still does not work. What can l do this remove this sign? |
.:: BIG PROBLEM WITH Huawei Modem !! ::. | The_Dj | FuriousGold | 2 | 10-07-2009 16:53 |
.:: BIG PROBLEM WITH Huawei ::. | The_Dj | FuriousGold | 9 | 10-02-2009 22:38 |
infinity team help with Huawei T201 | nellabe | Infinity-Box | 4 | 10-15-2008 12:18 |
problems with huawei e220 unlock | sir_sevilla | KULANKENDI Server | 1 | 07-08-2008 16:02 |
Can i use pin finder with Huawei T201 ? | summer_20xx | Infinity-Box | 9 | 04-01-2008 21:56 |
