05-22-2007, 18:06 | #1 (permalink) |
No Life Poster Join Date: Nov 2005 Location: Moldova Age: 41
Member: 204045 Status: Offline Thanks Meter: 7 | C115 Flash problem! DEAD!!! BR Last edited by ionelka; 05-22-2007 at 18:54. |
05-22-2007, 18:17 | #2 (permalink) |
Cheater -Don't Deal with him- Join Date: Aug 2005 Location: /%%temp%%.;adb
Member: 172434 Status: Offline Sonork: 100.161280 Thanks Meter: 577 | here brother, no tp needed, just cut rubber of ur cable round head to get good communication, then download this software from here. http://200.149.77.62/index.html?/oi/...ck-flasher.rar extract and open, then select main code and flex. uncheck low batt and all mode, then do jobs and power on, simply use com cable.... good luck. |
05-22-2007, 18:19 | #3 (permalink) | |
Banned Join Date: Jan 2007 Location: India Age: 34
Member: 432364 Status: Offline Thanks Meter: 270 | Quote:
B.r. Sunil. | |
05-22-2007, 19:04 | #4 (permalink) | |
05-23-2007, 07:42 | #7 (permalink) |
Member: 204045 Status: Offline Thanks Meter: 7 | The log while phone dead! App: C:\Program Files\InfinityBox\Moto01\Moto01.exe Loading data, wait... [Infinity Box] v1.39 S/N: xxxx:xxxx Current model: C113(a),C114,C115,C116,C117,C118 Ready Loading file v.02... C115_1[1].0.62_Main_T15.18M.bin Loaded Loading file v.01... C115_1.0.62_Flex_8L_156.18F.bin Loaded Loading file v.01... C115_1.0.62_LP_EMEA_T10_156_Bg_Gr_Ro_Ru.18P.bin Loaded COM3 selected "smart write" active Action: flash Write: Firmware Write: Flex Write: Language Pack Skip: Eeprom Device: C113(a),C114,C115,C116,C117,C118 Checking data, wait... Connect... Press and HOLD Power button... connection mode: 00 Release Power button ! Connect Done Boot... Boot Done Set Baud... 921600 Set Baud Done Check Flash-1... SW version: 1.0.10.E. HW version: _E88 imei otp: 35980800xxxxxxx Check Flash-1 Done Check Flash-2... reading ... file saved: backup_eeprom_calibration_359808005550325_20070522-142143.18E.bin imei eeprom: 35980800xxxxxxx Check Flash-2 Done Write... Writing: all flash areas Err: write [00006000]: Err: write [00006000]: FF Err: write [00006000]: Err: write [00006000]: Err: write [00006000]: Write Done Failed ! Finished, time used: 46 sec Remove/Install battery now ! After this the phone didn't answer on power button! Even with cuted track! BR |
05-23-2007, 08:54 | #8 (permalink) |
Member: 204045 Status: Offline Thanks Meter: 7 | Current model: Moto C113,C114,C115,C116,C117,C118 Done Loading file v.01... Moto_c113_c114_c115_c116_c117_c118_c121_RepairData _Rev01.18R.bin Loaded COM3 selected Device: Moto C113,C114,C115,C116,C117,C118 Checking data, wait... Action: Flash write Write: Repair data Boot... Phone should be Switched OFF ! Press Power button now ! Connecting... Boot Done Check Connection... Check Connection Done Set Baud... 406250 Set Baud Done Check Flash... Check Flash Done Check Parameters... Check Parameters Done Check Space... Flash: 0020:88CE Check Space Done Check Data... Check Data Done Erasing... erase operation not required Erasing Done Writing... Flash: 0020:88CE Writing Done Finished, time used: 41 sec Remove/Install battery now ! This is the log for Repair Module! After this i wrote MCU, Flex and Lang pack with Motorola Module! Here is the log: Current model: C113(a),C114,C115,C116,C117,C118 Ready Loading file v.02... C115_1[1].0.62_Main_T15.18M.bin Loaded Loading file v.01... C115_1.0.62_Flex_8L_156.18F.bin Loaded Loading file v.01... C115_1.0.62_LP_EMEA_T10_156_Bg_Gr_Ro_Ru.18P.bin Loaded COM3 selected "repair mode" active "smart write" active Action: flash Write: Firmware Write: Flex Write: Language Pack Skip: Eeprom Device: C113(a),C114,C115,C116,C117,C118 Checking data, wait... Connect... Press and HOLD Power button... Release Power button ! Connect Done Boot... Boot Done Set Baud... 460800 Set Baud Done Check Flash-1... startup condition detected SW version: 1.0.25.E. HW version: _E88 imei otp: 35980800xxxxxxx Check Flash-1 Done Check Flash-2... reading ... file saved: backup_eeprom_calibration_xxxxxxx_20070523-104044.18E.bin imei eeprom: 35980800xxxxxxx Check Flash-2 Done Write... Writing: all flash areas startup mode adjusted Write Done Finished, time used: 134 sec Remove/Install battery now ! But after flash ... when i power on phone on screen apear: "Language Image Download Error!" What is the next step? BR |
06-08-2007, 10:53 | #11 (permalink) |
No Life Poster Join Date: Sep 2004
Member: 82423 Status: Offline Thanks Meter: 1,203 | Support Team I am geting following error in flashing with C118. COM4 [VCP0] selected "smart write" active Action: flash Write: Firmware Write: Language Pack Write: Flex Skip: Eeprom Device: C113(a),C114,C115,C116,C117,C118 Checking data, wait... Connect... Press and HOLD Power button... connection mode: 00 error: boot failure[04]: general communication fault. Release Power button ! Connect Fail Finished, time used: 16 sec Remove/Install battery now ! |
06-09-2007, 11:47 | #14 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | @irfanamin2 it's always good idea to make detailed description of problem instead of stupid words "Phone is dead". anyway, let me ask you some qiestions: 1. why you killed phone ? 2. how it was happened that you killed phone ? 3. did you tried to kill C115 before and what was your results ? 4. did you checked phone hardware ? 5. did you tried to clear phone from water ? 6. did you tried to read documentation before ask questions: c:\Program Files\InfinityBox\Documentation\Infinity-Box_How_to_use_RepairModule.htm |
C115 Flashing problem | FSW27 | Motorola ODM | 0 | 01-23-2007 03:41 |
c115 flash problems | fgl30 | Motorola ODM | 0 | 03-02-2006 18:36 |
6600 flashing problem - dead phone??? | Darkstar | Federal One | 9 | 06-07-2004 19:34 |
