c139 tracfone after removing N1 ball.. flashing problem hi there infinity team! kindly check the image.. is this the right flashing logs?? http://i37.photobucket.com/albums/e9...on/retry-1.jpg i removed th N1 ball coz its a new type of PCB... but after reinstalling the cpu, i flashed it with 1.xxxx flash files now im getting that result in flashing.. is that right? i also put check on cutted track before flashing... please guide me.. thanks alot! |
just try to flash again using RPS instead of battery... |
hello! better post full log instread of screenshot. need to see all from begining |
here is the log... kindly check please Code: Finished, time used: 57 sec |
hello! MCU is soldered back incorrectly some data lines are missing |
so is it possible that i damaged the chip already?? if ever it is damage.. can i get from other phones and replace it? i reballed it thrice already but still the same result.. thanks for your reply! |
Hello! all 3 times same result? same data readed ? |
try reballs the cpu i have same problem but i reball again the cpu my problem solve. 10005 WORKING |
