07-04-2007, 17:40 | #1 (permalink) |
Freak Poster Join Date: May 2006
Member: 285074 Status: Offline Thanks Meter: 20 | c139 TRACFONE impossible to unlock C139_1.0.24_Flex_FFN_4R_10X.31F.bin C139_1.0.24_LPN_NA2_00X_Fr_EsLA.31P.bin C139_1.0.24_Main.31M.bin i push write. but i cant unlock it. COM8 selected "smart write" active Action: flash Write: Firmware Write: Flex Write: Language Pack Skip: Eeprom Device: C139,C140 Checking data, wait... Connect... Press and HOLD Power button... connection mode: 00 can you help me ..... |
07-04-2007, 17:45 | #2 (permalink) | |
No Life Poster Join Date: Oct 2005 Location: SALMAN SOFTWARE SADDAR RWP
Member: 194511 Status: Offline Sonork: 03335548581 Thanks Meter: 1,607 | Quote:
mostly this problem can b solved just restart ur pc then try it again | |
07-04-2007, 18:03 | #3 (permalink) |
Member: 285074 Status: Offline Thanks Meter: 20 | NO I restar my pc. and i have the same problem COM8 selected "smart write" active Action: flash Write: Firmware Write: Flex Write: Language Pack Skip: Eeprom Device: C139,C140 Checking data, wait... Connect... Press and HOLD Power button... connection mode: 00 Err: boot failure[04]: general communication fault. Release Power button ! Connect Fail Finished, time used: 59 sec Remove/Install battery now ! how can i see, ther version of software of my c139? |
07-04-2007, 19:28 | #4 (permalink) | |
Freak Poster Join Date: Apr 2006 Location: the Bahamas Age: 33
Member: 264055 Status: Offline Thanks Meter: 6 | Quote:
07-05-2007, 00:46 | #7 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | It's good idea to visit "Documentation" folder on your HDD from time to time. C:\Program Files\InfinityBox\Documentation\ Infinity-Box_How_to_unlock_C113-C118_2.3.65N_and_newest.htm (the same method for C139) Infinity-Box_How_to_unlock_C139_TracFone.htm Infinity-Box_How_to_fix_c115-C139_boot_error_version_mismatch.htm |
07-05-2007, 01:09 | #8 (permalink) |
Member: 264055 Status: Offline Thanks Meter: 6 | here you go. http:///vbb/showthread.php?t=334357 http:///vbb/showth...=334357&page=9 This thread helped me a lot when I had this problem. B.R. P.S Infinity support got really pissed at the end of the thread for some reason. It should make for a good laugh. |
07-05-2007, 08:43 | #10 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | @berks next time you must write your messages in correct thread. Let's respect each other, please. btw, before you write here your new "super-advice" please, read this: http:///vbb/showpo...42&postcount=4 |
09-01-2007, 09:48 | #11 (permalink) |
Registered User Join Date: Aug 2007 Location: bohol philippines Age: 42
Member: 572549 Status: Offline Thanks Meter: 175 | Remove Cpu Sir Then Remove N1 Flash Again Problem Solve. Tested By Me 100% Working Sir Just Try Carefully Remove Cpu And Reballs It Except N1. |
10-07-2007, 15:39 | #13 (permalink) |
No Life Poster Join Date: Apr 2006 Location: WestSide Age: 38
Member: 254137 Status: Offline Sonork: 1592525 Thanks Meter: 275 | @bachatia Your phone may have hight version and need to CUT, Repair then flash to revive it like C113 V.2xxxx and be carefull u can loose screen if bad cut track. |
Is Nokia 5320 Xpress Music impossible to unlock with the DKBB5 TRK Unlocker? | asgarcymed | BB5 Box by D.K. | 5 | 09-24-2009 22:21 |
C139 tracfone 850mhz to 900mhz | nyakam | Infinity-Box | 1 | 01-21-2008 13:44 |
Impossible to unlock 6300 v5.00 ? Where to put GND ( black crocodile) ? | gsmnice | BB5BOX | 43 | 10-06-2007 00:15 |
C139 tracfone convert to 900Mhz | mihy | Infinity-Box | 3 | 02-07-2007 18:25 |
Impossible to unlock new Talkabout with roemmi or newest unlock clip!!! | alro | Motorola Old Legacy (EMMI) | 14 | 10-16-2001 10:47 |
