03-01-2008, 11:28 | #1 (permalink) |
Freak Poster Join Date: Jun 2006
Member: 301263 Status: Offline Thanks Meter: 1 | c140 with white display Application: C:\Program Files\InfinityBox\Moto01\Moto01.exe Loading data, wait... [Infinity Box] v1.44 S/N: 0A3C:010C Current model: C113(a),C114,C115,C116,C117,C118 Ready Current model: C139,C140 COM19 ready Loading file v.01... C139_1.0.03E_Main.31M.bin loaded Loading file v.01... C139_1.0.03E_LP_T10_10C_Bg_Gr_Ro_Ru.31P.bin loaded Loading file v.01... C139_1.0.03E_Flex_2Q_10C.31F.bin loaded COM19 [VCP0] selected Action: flash Write: Firmware Write: Language Pack Write: Flex Skip: Eeprom Device: C139,C140 Checking data, wait... Connect... Press and HOLD Power button... connection mode: 00 error: boot failure[04]: general communication fault. Release Power button ! Connect Fail Finished, time used: 251 sec Remove/Install battery now ! COM19 [VCP0] selected Action: flash Write: Firmware Write: Language Pack Write: Flex Skip: Eeprom Device: C139,C140 Checking data, wait... Connect... Press and HOLD Power button... connection mode: 00 error: boot failure[04]: general communication fault. Release Power button ! Connect Fail Finished, time used: 9 sec Remove/Install battery now ! COM19 [VCP0] selected Action: flash Write: Firmware Write: Language Pack Write: Flex Skip: Eeprom Device: C139,C140 Checking data, wait... Connect... Press and HOLD Power button... connection mode: 00 Release Power button ! Connect Done Boot... Boot Done Set Baud... 460800 Set Baud Done Check Flash-1... SW version: 1.0.20 HW version: _E88 LP ver: LPE_C139_EMEA_T10_10C Flex ver: FFE_C139_04_10T imei otp: 353020012099231 Check Flash-1 Done Check Flash-2... reading ... file saved: C:\Program Files\InfinityBox\Moto01\\backup_eeprom_calibratio n_353020012099231_20080229-131642.31E.bin Check Flash-2 Done Write... Writing: Firmware error: write at 00000000: error: write at 00000000: error: write at 00000000: error: write at 00000000: E4 error: write at 00000000: 00 error: write at 00000000: 00 error: write at 00000000: 00 error: write at 00000000: Write Done Failed ! Finished, time used: 101 sec Remove/Install battery now ! |
03-01-2008, 12:39 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, You can try to use another flash files from support area (main + LP + Flex the same version). Also it may be that it's hardware problem, double check PCB near cutted track, it may be that other components was damaged when you tried to cut track. |
03-01-2008, 15:27 | #4 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, I am not sure that it was regarding c139/c140 but I heard some times about simlar problem and it was because of wrong tracks was cutted or some components near track was damaged. It's quite hard for me to remember now how that problem was solved, please, try to make "search" in this forum or look inside hardware repair section. btw, did you tried to use another flash files ? |
03-01-2008, 15:58 | #5 (permalink) |
Member: 301263 Status: Offline Thanks Meter: 1 | tried also other flash files from support but i don't understand one thing...i couldn't find the flex version that the phone had before and i was thinking, maybe this could be the answer to my problem. |
6600 turns off with white display.. | LankaGsm | Nokia Hardware & Hardware Repair | 1 | 12-15-2008 11:12 |
How to revive SE Z610i ?¿ It´s dead with White Display | Grupo MovilFree | KULANKENDI Server | 3 | 02-05-2008 13:25 |
A60 Only Beeps with White Display... | Afzaal | E-Gold Based Phones | 4 | 03-28-2007 19:53 |
K750i with white display | bcnboy | Cruiser Suite | 0 | 09-03-2005 19:33 |
