03-10-2009, 19:56 | #1 (permalink) |
No Life Poster Join Date: Aug 2005
Member: 175945 Status: Offline Sonork: ziiyyaad Thanks Meter: 704 | w375 net 10 still locked afetr unlock.. Action: read information Device: W375 Checking data, wait... Connect... Press and HOLD Power button... rom version: 0411 Connecting... initial boot phase complete Release Power button ! Connect Done Boot... Boot Done Set Baud... 115200 Set Baud Done Check Flash-1... SW version: 6.9.75 HW version: MOTOROLA_H80S LP ver: Flex ver: FLEX_A7_002 cpu id: 08B6 imei eeprom: 3583080105397805 required SW version: 0.0.62 Check Flash-1 Done Check Flash-2... Finished, time used: 16 sec Remove/Install battery now ! |
03-10-2009, 22:32 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Power on phone without sim card Type #02# Check software version. If version is "K2" you need to flash phone with ordinary W375 firmware, f.e. version 0.0.62 |
03-11-2009, 04:34 | #3 (permalink) |
Member: 175945 Status: Offline Sonork: ziiyyaad Thanks Meter: 704 | sw version 001c0062 Who: sw_cm sw ver: sw_w375_6.9.75.k2 flash:N/A version info. Code.90.01 boot.90.05 fmgr.90.81 flex_w375_a7_002 langpack: lp_w375_6975_NA1 chip ver x etc is 0.0.62 ok or higher version for this model? i need to flash only main and lp? |
03-11-2009, 21:37 | #4 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, You need to flash main + lp version 0.0.62 and any Flex file from flex_original folder |
P1i CID 52 still locked after unlock | zigma300 | Universalbox | 0 | 11-15-2007 14:49 |
k 550 im still locked after unlock with full flash ( mt se ) | datagsm | MT-BOX | 7 | 11-12-2007 16:23 |
E250 still lock after unlock with V2.0.5 | preshaust | NSPRO | 24 | 04-17-2007 12:14 |
Mot w220 still locked after unlock | Stylo_GSM | IQ-Box | 1 | 03-01-2007 18:51 |
x70 still locked after unlock with griffin server | gamdadda | Griffin | 3 | 05-29-2005 17:54 |
