Old 09-25-2010, 17:33   #1 (permalink)
Member: 242451
Thanks Meter: 63
Exclamation check bug on chinese miracle module 3.22
working chinese phone like daily, some dont write imei in option "default inside firmware". I format, repair security, flash eeprom but no succesfull so I had to use old module for repair
LOG MODULE 3.22
==== [24/9/2010 04:12:06 p.m.] ====
COM6 [VCP0] selected
module v3.22
Device: Autodetect 6205-6239 NOR
Checking data, wait...
Action: "repair imei"
imei write channel: imei #1 (default imei inside firmware)
new imei: 354841050009405
====> Boot ...
19200 fixed
Connecting, wait...
Initializing [6225:8A05:8A00]...
CPU: MT6225
high speed boot On
chip: 0001:E003:000B
status: FF
boot packet size: 0400
Release Power button now !
Boot Done
====> Initialize ...
flash: 98000300000001:18E59F00000000
flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb
otp offset: 00FE0000
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
number of flash chip/regions detected: 04/01
Initialize Done
====> Set baud ...
921600
Set baud Done
====> Initialize bootcode ...
Initialize bootcode Done
====> Check firmware integrity ...
device parameters detection in progress...
it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
usb bootloader detect...
usb bootloader detect (phase #2)...
usb bootloader (chip) is absent
searching rom info...
search rom info finished
rom info structure: [standard] type (04)
TCL-ID is absent
rom info detection finished
rom info ver: 04
sw version: C92_A_PCB01_GPRS_MT6225_S00.GEMINI_W08_00_0.BIN
project-id: C92_A.GEMINI.W08.00.0, 00000000
code offset: 00000000
ffs offset/size [01]: 00E00000/00200000
TCL-ID is absent
detecting ffs/eeprom area in 1 chip(s)...
standard ffs/eeprom offset detected: 00E00000
standard ffs/eeprom offset confirmed: 00E00000
detecting ffs/eeprom size...
ffs/eeprom size: 00200000
ffs/eeprom chip: 00
ffs/eeprom area: 00000000:00E00000-00FFFFFF
firmware area: 00000000-00DFFFFF
detecting startup code area #2...
startup code area #2 is absent
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
Check firmware integrity Done
====> Check firmware content ...
Check firmware content Done
====> Backup required data ...
Backup required data Done
====> Patch required data ...
detecting ffs/eeprom structure pass 2...
nfi area detection...
warning: source data is absent
nfi area detection (0 cores) finished: failed
error: ffs/eeprom detection failed element #2
error: can not detect default imei value
Patch required data Fail
Finished, time used: 1 min 17 sec
Remove/Install battery now !
now LOG MODULE 3.17
==== [24/9/2010 05:28:52 p.m.] ====
module v3.17
new imei: 356422510000249
====> Boot ...
19200 fixed
Connecting, wait...
CPU: MT6225
high speed boot On
chip: 0001:0103:0003
status: FF
Boot Done
Initialize Done
====> Set baud ...
921600
Set baud Done
rom info structure: 2nd [standard] generation
TCL-ID is absent
rom info ver: 04
TCL-ID is absent
ffs/eeprom chip: 00
ffs/eeprom: detect std location pass #1...
ffs/eeprom: detect standard offset pass #1...
ffs/eeprom record offset detected
ffs/eeprom: detect standard data...
ffs/eeprom record size detected
ffs/eeprom layout detection complete
ffs/eeprom detected ok element #2
imei default found: 13579024681122
Patch required data Done
====> Special operation ...
Special operation Done
====> Write ...
Write: imei
Write Done
====> Finalization ...
ffs formatting...
Finalization Done
Finished, time used: 2 min 1 sec
The Following 2 Users Say Thank You to pulian For This Useful Post:
6110 power does not stay on sc~micro Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 08-30-2014 08:14
what prog changes imei on 6110 and how do i do it? Ravetrancer Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 07-31-2012 20:09
Page generated in 0.22216 seconds with 9 queries
