06-29-2008, 14:48 | #1 (permalink) |
No Life Poster Join Date: May 2008 Location: COME & MADE GREEN WORLD
Member: 771937 Status: Offline Sonork: 100.1605717 Thanks Meter: 1,052 | can anybody help nktel n77 problem? Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: reset Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6225:8A03:8A00]... CPU: MT6225 high speed boot enabled chip: 0001:A903:0001 boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 7699BC9BA4A84E:7699BC00000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #01 in region #00... flash: 7699BC9BA4A84E:7699BC00000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #02 in region #00... flash: 7699BC9BA4A84E:7699BC00000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #03 in region #00... flash: 7699BC9BA4A84E:7699BC00000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud... 460800 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: 7699BC9BA4A84E:7699BC00000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #01 in region #00... flash: 7699BC9BA4A84E:7699BC00000000 flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb it's time to stop: 7608BC9939E7CC2A5182CB17F4181C2A7CDF950A1EBB8F1A number of flash chip/regions detected: 01/01 total flash region size: 00800000 detect device identification#1... detection phase #1... . detection phase #2... .................................................. .................................................. ............................ warning: identification#1 information not found, possible reasons: .old firmware type w/o identification#1 data .damaged firmware .damaged hardware if phone works fine just ignore this warning detect device identification#1 finished detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset assigned: 00700000 flash: 7699BC9BA4A84E:7699BC00000000 checking area[00000000]: 00000000-007FFFFF... Can't detect eeprom/ffs area Do you want to use standard ffs address: 00700000 ? If you are not sure that standard address is correct: 1. press "NO" and terminate current operation 2. make flash backup for emergency case 3. repeat required operation standard ffs address selected by user detecting eeprom/ffs size... eeprom/ffs size: 00100000 ffs chip: 00 eeprom/ffs area: 00000000:00700000-007FFFFF Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... reading [eeprom]... file saved: C:\Program Files\InfinityBox\ChineseMiracle\eeprom_20080629-190942.B0E.bin flash: 7699BC9BA4A84E:7699BC00000000 Backup required data Done Patch required data... Patch required data Done Special operation... Special operation Done Write... Write Done Finalization... formatting... flash: 7699BC9BA4A84E:7699BC00000000 error: no any expected answer error: flash erase error: 00710000 error: no any expected answer error: erase #E2 Finalization Fail Finished, time used: 97 sec Remove/Install battery now ! THIS IS MY LOG AND SET IS DEAD CONDITION, WHEN I FLASH THIS FILE THIS ERROR IS SHOW. CAN ANYBODY HELP WHAT IS RIGHT FLASH FILE. Last edited by debmobile; 07-01-2008 at 02:34. |
06-29-2008, 19:28 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Phone hardware is damaged, you must reball flash chip as a first step. Why flash chip damaged ? You must check operation log carefully... Code: flash: 7699BC9BA4A84E:7699BC00000000 |
Can anybody help me after flash N93i video rec problem big strange noice??? | sokolibrahimi | MT-BOX | 2 | 12-18-2007 19:44 |
BB5 rpl problem! Can anybody help me? | Gsm-W | MT-BOX | 17 | 08-23-2007 12:05 |
can anybody help me to solve this problem ????? | GIGOLO | Nokia Multimedia | 0 | 10-19-2005 08:21 |
Problem With A800 ,can Anybody Help ! | TWISTER_FLasher | Twisterflasher | 3 | 06-07-2004 17:09 |
I have big problem with motorola t205 with charging can anybody help me ??? | ZetMen | Motorola ODM | 3 | 09-11-2003 00:33 |
