Old 11-21-2009, 07:42   #1 (permalink)
Member: 1086393
Thanks Meter: 771
Arrow Calibrate did'nt go even with 2.99
Hi, I try to remove one chinese phone CECT C828, Calibrate touch-
heres the logs:
COM10 [VCP0] selected
module v2.99
Action: touchscreen calibration
How to calibrate touchscreen:
- for this operation you need to have full flash backup from phone
- if you have full flash backup already press "Yes", select full flash file and follow instructions given by software
- if you do not have full flash backup yet press "No", read full flash and repeat calibration procedure
Do you have full flash backup ?
Loading file v.02...
E880_BLJ1SETF10_E880_GPRS_MT6225_S00.01_4__fullfla sh_20091121-114137.B0M.bin loaded
ffs/eeprom record offset detected
ffs/eeprom record size detected
Model: Autodetect 6205-6227 NOR
Checking data, wait...
19200 autodetect
Initializing [6225:8A03:8A00]...
CPU: MT6225
high speed boot On
chip: 0001:8303:0006
status: FF
Connecting at 19200, wait...
Release Power button now !
Phone detected, wait...
Hardware: MT6225,E03
Date: 2006.06.14
Version: 1.0
Version: E880_EVTST.01.0_25S00
Version: EVEN25_HW
44 byte(s) read
imei: 35782800001475
connection Ok
512 byte(s) read
167 byte(s) read
reading data #2...
512 byte(s) read
writing data...
verification...
verification Ok
Finished, time used: 18 sec
Remove/Install battery now !
but calibrate did'nt go- i format with safe mode and again repeat procedure but still same!!!!!!
whats the problem with this phone????
Old 11-21-2009, 12:39   #2 (permalink)
Member: 130995
Thanks Meter: 35,227
What you see at phone LCD when you power-on phone with sim card ?
Old 11-21-2009, 12:48   #3 (permalink)
goherabbas's Avatar
Member: 1311812
Sonork: 1659061
Thanks Meter: 116
bro full flash this or then calibrate tuch all will be work ok
your bro
gohar abbas
Old 11-21-2009, 14:20   #4 (permalink)
javeed_mp's Avatar
Member: 1166187
Sonork: 100.1616368
Thanks Meter: 168
complete ffs then do calibrate
Old 11-22-2009, 01:43   #5 (permalink)
Member: 148515
Thanks Meter: 19,534
heres the logs:
module v2.99
19200 autodetect
CPU: MT6225
high speed boot On
status: FF
Date: 2006.06.14
Version: 1.0
Version: EVEN25_HW
44 byte(s) read
connection Ok
512 byte(s) read
167 byte(s) read
reading data #2...
512 byte(s) read
writing data...
verification...
verification Ok
hello!
you picking flash file which is different to your phone software version.
please read out full flash and use it for calibrating
Page generated in 0.15536 seconds with 9 queries
